typical leaking trunk
Old Mar 20, 2012 | 04:15 PM
ADROX's Avatar
so I've heard several people end up with leaking trunks but hadn't heard the typical solution. is it just the weatherstripping seal around the trunk? looked around but just don't see an obvious answer. at one time I actually pushed on the metal section (inside the trunk) between the back landing and the trunk. seems to be a double layer there, anyway when I pushed on it a good amount of water came out. anyone have any ideas?
Old Mar 20, 2012 | 04:45 PM
pflicht's Avatar
A quick fix, you could silicone the inside of the trunk where the bolts are
Old Mar 20, 2012 | 05:57 PM
ADROX's Avatar
don't have a spoiler or anything so not sure which bolts you are referring to.
Old Mar 20, 2012 | 06:25 PM
njmaxseltd's Avatar
Most trunk leaks are from the tail lighs.
The large lip around the trunk makes it virtually impossible for water to get it.
Check the spoiler mounts, if you have one.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
uttadms31
Sep 30, 2015 05:24 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
