Need help! Transmission swap
Old Mar 22, 2012 | 06:09 PM
june19's Avatar
I have a 97 maxima automatic transmission is gone,i found a auto tranny from a 00 maxima,i just need to know if it fit with no problem on my 97 can someone let me know. Thanks
Old Mar 22, 2012 | 07:13 PM
maxed_out_99's Avatar
i have an 01 trans from an I30 so heres what you will encounter (i will be as thorough as possible)
~the trans and mounts directly bolt up
~all sensors must be swapped from your 4th gen.
~the solenoids inside the valvebody must be cut and spliced because the connectors are in different positions between the gens. the colors remained the same so just cut solder and shrinkwrap and your done. to remove the "junction connector" remove a metal clip from the top and simply push it through the trans.
~the trans range switch must also be swapped. heres where it gets tricky,
~a bolt and nut must be installed due to the selector on the transmission itself.
the bolt must be ground down on both sides to fit securely.
you should have a buddy go through all the gears to ensure that the selector inside the car and trans range switch are in proper alignment.
the rest is just bolt and go. the best thing about swapping the 5th gen trans is that it goes all the way to redline beacuse it was engineered for the VI.
so if you were planning on swapping manifolds this is definitely the way to go.
i hope this helps. its not a simple R&R so any questions you have i will be more than happy to answer.
Old Mar 22, 2012 | 07:29 PM
june19's Avatar
Thank you so much for your help bro.
Old Mar 22, 2012 | 07:32 PM
Anytime.
I hope everything goes smooth for you if not just hit up the .org
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
I<3 A32's
Sep 10, 2015 11:07 AM
