secruity problem
secruity problem
well i have a 1999 Maxima Nissan, the security feature starts blinking once i open the door and insert the key, but once i crank the car it starts but then the security thingy turns all red and my car doesn't turn on, sometimes it turns on but turns off by itself
any help would be appreciated
99 maximas were the first to get the NATS (Nissan anti-theft system). It consists of a transponder chip inside the head of the key, and a receiver at the key cylinder. If your car is not starting, it's because the car isn't seeing the correct key.
For this car you CANNOT simply cut a key and use it....it must be a transponder key that has been programmed to the car at the dealer.
Some of the 99 maximas have been known to "forget" the keys, and they need to be reprogrammed by the dealer.
That right. Two locksmiths told me they could take care of the problem but when they got to my house and looked at it they were like "WOOPS I dont have the tools to reset it."
I ended up taking it to the dealer unfortunately. To reprogram the module and the key was about 85$ so it was not too bad. keep in mind this was 2 years ago.
This happened again to me but this time the NATS module gave out and they are not cheap!! So far I havent had any issues but if it pursues again... ECU SWAP!!
Good luck
Good luck
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
