Control arm bolts
Old Mar 30, 2012 | 03:17 PM
NABU6's Avatar
Control arm bolts
Quick question. Are all three bolts located on the control arm (the plate that holds the rear up) M14x1.50? I know one is slightly smaller than the other two. Anyone know the size of that bolt?
Old Mar 31, 2012 | 07:23 PM
NABU6's Avatar
Anyone?
Old Mar 31, 2012 | 08:07 PM
MAXIMA_STYLE's Avatar
remove one and bring it to parts store...dont tell me you managed to break one somehow??
Old Apr 1, 2012 | 04:53 PM
NABU6's Avatar
Oh, not at all. But I did manage to strip that bolt out and want to tap and die it. removing it is what I am going to have to do. Just curious if anyone new the size off hand.
Old Apr 1, 2012 | 07:30 PM
beegeezy's Avatar
I don't even know where you would find that info.
You have a thread pitch gauge, right? If I were to guess, I think your M14 x 1.50 is probably correct though.
Old Apr 1, 2012 | 10:37 PM
pkrainert's Avatar
Happened to me on one of the rear bolts. It is an m14 1.50 . I used a thead pitch gauge and a micrometer to figure that out. Then i used a helicoil kit with a 9/16ths drill bit. Be careful as you will be drilling into the frame. First though i would try an m14 1.50 tap to clean up the threads. Mine were too far out so i had to tap for a helicoil and use the insert. Has been fine for about 10k mile. The good kits are expensive i borrowed mine from a localachone shop. Also tou wont find a replacment bolt wiyh the correct harness and taper at the end in the store so be sure to order it.
Old Apr 1, 2012 | 10:39 PM
pkrainert's Avatar
Local machine shop* sorry hard to type on my phone.
Old Apr 1, 2012 | 10:40 PM
thedwyer00's Avatar
I know the pain. I actually had the nut for the bolt (yeah the one welded inside the frame) break off on my last maxi. I ended up having to cut the sub-frame open to weld it back into place.
Old Apr 1, 2012 | 11:22 PM
beegeezy's Avatar
Wow...now THAT sucks!
Old Apr 2, 2012 | 06:09 AM
NABU6's Avatar
Well, I'm going to tap and die it first, if that doesn't work, I'm going to use Time-serts. Suppose to be stronger than helipcoils.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
