Parts to Order for Water Pump Replacement?>
Can someone list all the parts to order for the replacement?
Any brands I should stay away from. I would like to go OEM but it's a bit out of my budget. Any recommended
brands?
Tnx
brands?Tnx
Well the problem for the 95's and 96's is that the tensioner that is available from Nissan is the updated part, that comes with one new chain guide as well. In order to replace the guide, the side cover of the engine must come off (according to the shop that did my car) and that adds major labor to the job. You can't use the new tensioner with an original guide, and you can't purchase an "old" style tensioner any longer. So on my car they cleaned up the original tensioner, and reused it. I returned the new tensioner and guide to Nissan.
Zack
Zack
+1
I would go OEM. A job like that you wouldn't want to do it twice because of a cheap part. Since DaveB is no longer around. I've been buying my oem parts from Brent Koenig at Gillman Nissan 281-341-2277. Just tell him your from .org and he'll apply a 20% discount. He replies to messages and is a cool guy to deal with. He has always given me the best prices for oem parts compared to other dealers...
+1
Thank you. Also what parts do I need to order for this job? I am taking it to a shop.
If OEM is out of your budget I have had good luck with RockAuto.com for friend's cars I have worked on (non-Nissan ughh).
Price Compare
CourtesyParts
Water Pump Assembly $89.70
Thermostat Assembly $20.52
Radiator Cap $14.58
Upper Radiator Hose $17.88
Lower Radiator Hose $20.22
TOTAL $162.90
RockAuto
Water Pump Assembly $44.79 (Beck/Arnley close to stock)
Thermostat Assembly $16.93 (Beck/Arnley Includes seal, housing and thermostat)
Radiator Cap $4.97
Upper Radiator Hose $10.97 (Goodyear)
Lower Radiator Hose $17.59 (Goodyear)
TOTAL $95.25
If you can afford to go $70 more I would go OEM. Also if you can afford the 4 OEM radiator hose clamps @ $2.56 each since yours are probably 17 years old I would do yourself a favor a replace them. You will thank me and so will your mechanic as they will weaken and break. Finally don't put worm-drive clamps on them it will only ruin the hoses and makes for a sloppy install.
Price Compare
CourtesyParts
Radiator Cap $14.58
TOTAL $162.90
RockAuto
Radiator Cap $4.97
TOTAL $95.25
Oil and anti-freeze will mix on the water pump change, so change both fluids.
Anti-freeze;
Nissan or better anti-freeze
thermostat
ECT or temp ssensor for ECU
Oil
Oil Filter (wix or equivalent)
5W30 or 10W30 oil
That's about it.
DW
Anti-freeze;
thermostat
Oil
5W30 or 10W30 oil
That's about it.
DW
Price Compare
CourtesyParts
Radiator Cap $14.58
TOTAL $162.90
RockAuto
Radiator Cap $4.97
TOTAL $95.25
Price Compare
CourtesyParts
Radiator Cap $14.58
TOTAL $162.90
RockAuto
Radiator Cap $4.97
TOTAL $95.25
vingodine
45
May 21, 2016 12:46 PM
kirkhilles
Aug 8, 2015 10:53 AM
