Starting problem = Stupid battery cable design
Old Apr 7, 2012 | 06:20 AM
mhcomp's Avatar
I had tried to post about this before but don't know what happened. Please excuse if this is a duplicate post.
My 99' had very intermittent starting problems and to make a long story short, I wound up replacing everything except the neutral switch in the transaxle. Before doing that I had a hunch that I may have a grounding problem so I jury rigged a ground to the engine. Problem disappeared.
Now to find the cause, I unhooked the battery cables and the negative cable fell out in my hand. The clown designers at Nissan had put a compression fitting about a foot or so from the cable end on the negative cable (Why? - Who knows) and it had worked itself loose over the years.
So if you are having starting problems, the negative cable may be the first thing to look at.
Old Apr 7, 2012 | 09:53 AM
RA030726's Avatar
I'm nutty for Nissans
The ground wire connects to the chassis, under the intake box, then to the engine with some lame little bracket. The chassis connection must have corroded and loosened up. Good catch.
Old Apr 7, 2012 | 11:35 AM
RA121625's Avatar
Big 3 upgrade is always a good idea for any car.
Old Apr 7, 2012 | 12:12 PM
mhcomp's Avatar
Nope! Here is a pic of the cable. The splice was before the cable connected to the chassis and then on to the block. I have had this car since it was new and I surely didn't do this and have always done my own maintenance. The splice had a plastic cover over it (see pic) so it wasn't apparent by looking at the cable. The end just came apart in my hand when I removed the cable end from the battery.
Old Apr 7, 2012 | 03:08 PM
asand1's Avatar
AFAIK Nissan didn't use a cast battery terminal clamp. You sure you didn't have someone install a battery and make "improvements"?
Old Apr 7, 2012 | 04:11 PM
mhcomp's Avatar
Boy, being an old fart, I am trying to remember if that maybe did happen in 2003 when the second battery went in. If so, I am out of line blaming design for the problem.
Thanks for jogging my memory.
Old Apr 7, 2012 | 04:31 PM
ShocknAwe's Avatar
Yea looks like they added that length in there to avoid replacing the whole thing and didnt know how to clamp right lol. Nissan had very few design flaws on the 4th gen in general
Old Apr 7, 2012 | 05:26 PM
RA121625's Avatar
Lets not get carried away here. I invite you to search the TSBs for the 4th gen. There are very few cars that have "very few design flaws".
Old Apr 7, 2012 | 07:23 PM
zach-eminem's Avatar
nissan put in the compression fitting midway down as a chassis ground mine has it too 99.5 sel its there for a reason and mad expensive to get from nissan like 78 bucks i think
Old Apr 8, 2012 | 04:43 AM
njmaxseltd's Avatar
That's not on my 99.5 SEL.
That cable is an aftermarket. The OEM battery connector isn't cast. It's a sleeve clamp style. It's obvious somebody spliced that new end onto the wire.
Old Apr 8, 2012 | 05:38 AM
Trini Boom's Avatar
Agreed. This cable is not OEM but if you want to ewplace, use the 00-01 cable. It has an extra grounding point.
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Tha'-Max
Aug 30, 2015 01:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
