Why you shouldn't use an aftermarket radiator support......
Old Apr 11, 2012 | 03:59 AM
KRRZ350's Avatar
5-speed w/'00vi, equal length e-bay headers, & deluboz 3.5l cams ripped this thing out in short order.......
Old Apr 11, 2012 | 04:20 AM
Akiyukio's Avatar
Is it me, or is the thickness of that support EXTREMELY thin?
Old Apr 11, 2012 | 04:25 AM
KRRZ350's Avatar
Not just you, it's cheesy & whicked thin
Old Apr 11, 2012 | 04:56 AM
95naSTA's Avatar
What's weird is that under load the cross member pushes up on the lower rad.
So, unless you went nuts in reverse, the weight of the engine/trans did that.
Old Apr 11, 2012 | 06:09 AM
IRBatman's Avatar
Yikes! I just had the lower rad support replaced on mine. Glad I got the OEM part, the prices on those aftermarket ones were definitely tempting. Thanks for the pic.
Old Apr 11, 2012 | 06:54 AM
cashoit's Avatar
I bought one from a parts store. About 7 months after install I noticed the same thing!!!
Mine had started to droop a lil so i had my mech weld it up for me. I check on it every few days make sure its good.
@ KRRZ,
When this happened, did it harm the engine or what affects did it have on the car other than the support breaking?
I have always thought that the other mounting points were robust enough so that the nothing else would happen to the car.
Old Apr 11, 2012 | 08:02 AM
mrjasonlyrics's Avatar
Yikes. That's the first time I ever seen something liKe that. How much is it to relace it including labour???
Old Apr 11, 2012 | 08:04 AM
L_U_D_I_AMaxima's Avatar
wow where did you get the radiator support frame from?
Old Apr 11, 2012 | 08:05 AM
I just picked up an aftermarket for mine 2 days ago, haven't installed it yet but I will check how thick it is before I do all the work...
Old Apr 11, 2012 | 08:20 AM
Snypa's Avatar
wthhh man. Thats just some ridiculous **** right there !!
Old Apr 11, 2012 | 08:43 AM
thedwyer00's Avatar
That is a MAJOR issue with the ****ty aftermarket core supports. Mine did the same after a couple of months of replacement. My bro had the same issue but was able to catch it before it did too much damage and had another piece of metal welded over it to strengthen it up. Have fun re-fixing that... I feel your pain.
Old Apr 11, 2012 | 08:45 AM
FlaMaxima29's Avatar
Youtube A/m rad supports they do a stength test and its crazy.. I deal with them daily..
Old Apr 11, 2012 | 09:10 AM
wirelessdude04's Avatar
eBay rad supports suck. I'm getting mine done soon also but gonna get angle iron peices welded across the front. Everyone I know has done that and it works and won't go anywhere. Those eBay ones are flimsy and garbage cheap thin metal
Old Apr 11, 2012 | 09:13 AM
aackshun's Avatar
http://www.courtesyparts.com/62530m-...-p-126547.html
Isn't that expensive.... If you're on a time crunch (or cheap like me) and you live in the south goto a local J/Y and pick one up....
Old Apr 11, 2012 | 03:54 PM
J_MAxxX's Avatar
my gosh that thing is thin if your OEM looked like that you could've got it welded since it's thicker...but this nahh go oem man
Old Apr 11, 2012 | 04:06 PM
ShocknAwe's Avatar
Isnt it the 4th gen bumper support that was re-designed into a lighter but stronger aluminum frame? You would think Nissan could upgrade the design on this as well and make it stronger yet lighter. Its funny to see what parts Nissan decides to upgrade in design and what they dont. Kind of like the rad drain plug. Its plastic lol WTF? YOu would think they could go metal with it very easily but decided not to. That sucks about the quality you got though. Could you not tell how thin it was before the install? You would think you could have just tapped on it to see how thin the damn thing was. Sorry about that. Lesson learned though
Old Apr 11, 2012 | 04:14 PM
carnalc30's Avatar
http://forums.maxima.org/4th-generat...hout-rust.html
I had the same problem, though not as bad, I had a 1/4 plate welded along the bottom of it and fixed it. Its holding up fine now
Old Apr 11, 2012 | 04:30 PM
GGENIUS's Avatar
who the **** cares if the rad drain plug is metal or plastic??
Old Apr 11, 2012 | 04:45 PM
ShocknAwe's Avatar
Obviously you do not know the advantages of not having to worry about stripping the plastic screw when draining your rad. A metal plug can also be magnetic which has other advantages. GGenius, just watch when you navigate through the .org and let the big boys who actually know something about cars lend advice ok? Dont say you have other people who use your account and other excuses for saying dumb stuff. Its you, your a troll. Leave. Its simple
Old Apr 11, 2012 | 04:48 PM
GGENIUS's Avatar
youre obviously an idiot if you strip your rad drain plug. even more simple.
and if you knew anything about cars, youd know that pretty much every car company makes their rads with plastic plugs now adays. seriously
Old Apr 11, 2012 | 04:56 PM
ShocknAwe's Avatar
Its plastic and it strips when you look at it. Thats why aftermarket rads come with metal drain plugs. Simple concept. Think about it
Miket2006
Mar 1, 2021 03:55 AM
bigdogsteve
Jan 31, 2018 04:18 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
