Couple Clutch Questions
Old Apr 18, 2012 | 03:56 PM
jayeyeMax's Avatar
i just recently needed to replace my clutch.
i ordered the oem 4th gen pressure plate
the 5th gen clutch disc
and going to resurface my flywheel
i also ordered the ss one piece clutch line from the master to the slave.
i cant seem to find any info on how to install these items.
pictures would help 100%
Old Apr 18, 2012 | 04:51 PM
maxgtr2000's Avatar
KH3 by popular demand
I just did all of the above. I have not seen a write up on the ss line but if you search for clutch line you will see a pic. You will have to remove 2 lines when you do the clutch line replacement. There is a write up in the how to section on how to pull the tranny. When you replace the clutch make sure you torque the pressure plate bolts to spec.
Old Apr 18, 2012 | 04:57 PM
beegeezy's Avatar
http://www.nicoclub.com/FSM/maxima/1995/cl.pdf
I think you have that backwards. Don't you want a 4th gen (or 5th gen) clutch disc with a 5th gen (20th Anniversary?) pressure plate?
Old Apr 18, 2012 | 09:26 PM
jayeyeMax's Avatar
i hope thats not true i just ordered a 5th gen clutch disc and a 4th gen pressure plate
Old Apr 18, 2012 | 10:50 PM
beegeezy's Avatar
If you were trying to get a clutch that handles more power, then yes, I believe it's true. IIRC, the 5th gen 20AE pressure plate is sprung more heavily, which gives the clutch more power holding capability. The discs are the same and so are the non-AE pressure plates between all 4th and 5th gen Maximas.
Old Apr 19, 2012 | 11:12 AM
jayeyeMax's Avatar
so basically i just ordered a oem 4th gen setup im not mad i just want it to work. will it work?
thanks for the info guys but were can i buy the 20th ae 5th gen pressure plate
Old Apr 19, 2012 | 11:50 AM
cashoit's Avatar
LukeGxe did a writeup on the SS lines
Old Apr 19, 2012 | 11:52 AM
aackshun's Avatar
http://aackshunsgarage.blogspot.com/...utch-line.html
Old Apr 19, 2012 | 08:19 PM
beegeezy's Avatar
Yeah, pretty much. It should work fine.
BkGreen97
Apr 2, 2016 05:47 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
