FSTB doesnt seem to be working for me!
Old Jan 4, 2002 | 01:12 PM
95maxgxe's Avatar
hey everyone i have had the FSTB installed for a while and it doesnt seem to make any difference. I have taken high speed turns too!! I think it might have something to do with the bar not being centered right or something when i installed it bc it is more to the right side than to the left. Would that make any difference? Thanks....also does anyone have a way to secure a subwoofer box?? bc when i turn the sub goes all over the place!
Old Jan 4, 2002 | 01:21 PM
clee130's Avatar
Ummm ... how can it be more to the right than to the left? It doesn't make a HUGE HUGE difference, it's more of a subtle mod. Make sure all bolts are torqued to 35-40 ft/lb.
Old Jan 4, 2002 | 01:32 PM
BlkCat
Do you mean that the strut towers don't line up with the holes in the bar?
Old Jan 4, 2002 | 02:31 PM
KWheelzSB's Avatar
I think he means that the bar is positioned off-center (looking down the middle of the engine bay) because of the way it is adjusted on the adjustment threads at each end of the bar. (I don't think he's referring to the mounting brackets where they secure to the 3 bolts on the strut tower)
P.S: As long as the bar is tightly secured and there is enough (+) pressure on the bar between the two strut-towers, whether it is slightly off center or not shouldn't affect it's performance.
Good luck!
Old Jan 4, 2002 | 02:59 PM
NickStam's Avatar
Re: FSTB doesnt seem to be working for me!
you're prolly used to it. you need to lower your car or something.
Old Jan 4, 2002 | 03:22 PM
95maxgxe's Avatar
Re: Re: FSTB doesnt seem to be working for me!
yeah maybe, i am planning on lowering it with drop zones and kyb agxs in the spring, but am getting a RSB now hopefully i will notice that a lot more!
Old Jan 4, 2002 | 03:41 PM
KWheelzSB's Avatar
Re: Re: Re: FSTB doesnt seem to be working for me!
That's a mod you will DEFINITELY notice. Faster turn-in (steering response) & much more stable in high-speed sweepers, etc.
It's really the biggest missing ingredient that cranks the vise down on that sloppy OE suspension!
Check the comments in this thread Re: RSB/RASB
http://forums.maxima.org/showthread....threadid=88568
Old Jan 4, 2002 | 03:51 PM
SpeedFrk38's Avatar
the rsb will make a huge difference. if you have the money, drop the suspension on the max and you'll see a MAJOR improvement.
good luck.
Old Jan 4, 2002 | 07:06 PM
yourmove's Avatar
I suggest going to www.westmarine.com search for cooler chocks! These are used on boats. They come in PVC, cast/chrome and other materials. I'm getting some chrome one's! These are intended to keep a cooler from moving around the deck of a boat.
Old Jan 4, 2002 | 07:43 PM
DARTHSWAN's Avatar
I went to Home Depot, purchased some brackets, and drilled through the floor. Sub no move, no mo.
K
Old Jan 4, 2002 | 08:24 PM
KWheelzSB's Avatar
K
I don't know if you used bolts or sheet metal screws, but if bolts, make sure you paint the bare-metal edges of the holes to prevent corrosion.
If sheet metal screws, then use clear silicone on the base of the holes under the bracket to seal it water-tight & reduce possibility of corrosion.
Glad you found a solution. Who needs those "extra" unwanted thumps of a sub box acting like a boggle cube in your trunk, right?!
Old Jan 5, 2002 | 01:52 PM
MaineMax's Avatar
I bolted my sub to the back seat frame. Works well.
Old Jan 5, 2002 | 02:10 PM
Mishmosh's Avatar
Some say the difference is huge, some say it is subtle. I say it is subtle and one you can easily get used to. And it doesn't make you forget about the understeer or the body roll... Get the other suspension mods and you will be happy. I've always said that with the FSTB, if someone stole it in the middle of the night, VERY few if any would notice it gone the next day.
Old Jan 5, 2002 | 02:34 PM
kmax's Avatar
I torqued the bar to ~32.5 ft/lbs. Does anyone know if this too low?
Thanks.
Old Jan 5, 2002 | 02:38 PM
guitaraus's Avatar
I just got mine, and I'm going to have to agree with this...it's nice, but not THAT nice!
Old Jan 5, 2002 | 03:52 PM
SpeedFrk38's Avatar
[QUOTE]Originally posted by yourmove
[B]does anyone have a way to secure a subwoofer box?? bc when i turn the sub goes all over the place
i've seen peeps use velcro. you can get big pieces from home depot and velcro your sub to the carpeting in the trunk. works so far.
Old Jan 5, 2002 | 04:59 PM
KWheelzSB's Avatar
The concensus seems to be that the FSTB is mostly appreciated on the track and during 'extremely' enthusiastic driving, whereas the RSB is a mod. you can appreciate every day.
RSB is definitely the one to get first, if you're prioritizing. . .
Old Jan 5, 2002 | 08:34 PM
mzmtg's Avatar
Minister of Silly Walks
I secured my sub box by cutting apiece of plywood to fit the bottom of the trunk and using brackets to bolt to that.
As for the FSTB, it is subtle. Before I had it, in high speed sweepers, bumps would make the car do a little side to side wiggle mid corner. As soon as I put on the FSTB, the wiggle was gone. That and high speed lane changes are more direct.
Subtle.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
cruce91
Sep 20, 2015 10:23 AM
Hailstatejig
Sep 2, 2015 06:52 AM
