Pesky P1320 Code
Old Apr 26, 2012 | 12:40 PM
ralexand88's Avatar
Pesky P1320 Code
Hey guys,
I need some help getting rid of this code. Up to this point, I have replace all coils packs with the BWD brand from PepBoys. I have also replaced my knock sensor which I wasnt 100% on but it was cracked when I removed it. I am attempting to perform the steps noted in the EC section of the manual.
Here are the problems I'm having.
1.) I am attempting to check continuity on the condenser but I dont think I have the right harness connector. It would appear that this thing is connected to my knock sensor but I could be wrong. In attempting this, I do not get a reading.
1.) Does anyone have an actual picture of this thing?
2.) And shouldnt I get all zeros on my multimeter?
In check the power,I get 3.3v when I think I should be getting the same voltage as the battery. Am I right with this assumption?
In using the multimeter, I dont get a reading from my coil packs. I think Im just using it wrong so any helps would be useful but I havent tested them since they were all purchased new. (Spark plugs are new also.)
If I decide to check the power supply using Step B in the manual (pg EC-420), how do I ground the multimeter?
Last one, when checking voltage under the hood, should I use the negative from the battery or use the chasis?
Thanks guys for the help. Hope that's not to much.
Old Apr 26, 2012 | 01:06 PM
infinimax96's Avatar
always buy OEM coil packs. Aftermarket ones tend to not last/perform as well as OEM.
check the wiring harness for damage. It's possible a wire got cut by accident and it's not sending a signal to something.
Old Apr 26, 2012 | 01:12 PM
SandyMax96's Avatar
OEM or Bust!
If it's too expensive, at least get used ones from the junkyard that are OEM
Old Apr 26, 2012 | 01:13 PM
Get OEM coils.
Old Apr 26, 2012 | 05:16 PM
Trini Boom's Avatar
Originally Posted by SBKMax96
OEM or Bust!
OEM Hanshins or Bust!!
Old Apr 26, 2012 | 07:12 PM
tigersharkdude's Avatar
BWD coilpacks will throw the P1320 code.........ask me how i know
Old Apr 27, 2012 | 06:57 AM
ralexand88's Avatar
This seems like such a hit and miss issue. I haven't read any post that would say people have done what Im being adviced to do which is basically get $600 dollars worth of coils from Nissan with the possibility of being stuck with the $375 worth already invested on the BWD. And I still won't know for sure if this will clear the code.
Old Apr 27, 2012 | 08:28 AM
Get used OEM coils. It'll solve your issue.
Old Apr 27, 2012 | 01:54 PM
tosheto's Avatar
I did that on two of my maximas and it worked.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
