fixed a couple of things on my 97 maxima
Old Apr 27, 2012 | 09:31 PM
geofferito's Avatar
I tried to fix some things on my car today. I guess 2 out of 4 is not two bad.
The overdrive on/off switch was broken when I got the car. I replaced the gear shifter and it works now.
I had a report on my car form the previous owner that the the BCM (Body Control Module) was bad and could have been causing the security system to be off or disabled. I replaced it. I haven't noticed any difference yet. I still cannot read the check engine codes.
My odometer was not working when I got the car. The miles are unknown on the car. I got a replacement odometer with 196K and now I will be able to figure out how bad my mpg is . As a side effect, my check engine light went out.
I replaced the digital clock with what I thought was a good one. It didn't work.
When I get more time, I still need to replace a front headlight and fix the passenger door handle.
Old Apr 27, 2012 | 09:55 PM
geofferito's Avatar
Quick update. I did the obvious. I replaced the 7.5 amp fuse that controls the clock and the security system.
Now my clock works and the car beeps at me when I don't have my seat belt on. It won't let me lock the doors with the door open. Additionally, when I lock the door from the outside the security light comes on.
I guess I fixed 4 out of 5 if you count the fact that I cannot program the keyfob.
Lakersallday24
Nov 7, 2024 07:31 PM
halfpol
Oct 17, 2022 12:16 PM
kirkhilles
Aug 8, 2015 10:53 AM
halfpol
Aug 5, 2015 08:24 PM
yat70458
Aug 3, 2015 01:16 PM
