Transmission Issues? Slipping?
Old Apr 27, 2012 | 11:17 PM
DBrames's Avatar
I have a 97 SE auto and i have noticed that under heavy acceleration or load the car will act a little funny. Engine speeds does not seem to increase steadily in the 3500-5500 RPM range. It is hard to describe what it does but it is not a rough jerking, more of just an unsteady acceleration. My first thought was the transmission was slipping but then one day i threw a code and turned out to be a misfire. Could a slipping transmission cause a misfire? This has happen a couple of times but only threw the code once. Anyone else have this issue or have any advice? Transmission fluid is nice and red and at a good level.
Old Apr 28, 2012 | 02:18 AM
Laevateinn's Avatar
A slipping transmission will make the fluid overheat. And poor acceleration can be caused by a misfire. So why was your car misfiring?
Old Apr 28, 2012 | 04:20 AM
iDuty's Avatar
"Could a slipping transmission cause a misfire?"
No.
Solve the misfire first.
3,800-5,500 rpm is the sweet range for the VQ30DE. It should run like a champ through that.
Old Apr 28, 2012 | 10:59 AM
DBrames's Avatar
I don't know why I had the misfire code, it only happened once. I know to get the engine light it must misfire 3 times but I've been watching the pending code and haven't seen any misfires, even after I see the acceleration issues.
Old Apr 28, 2012 | 11:28 AM
Shift_A32B's Avatar
replace all 6 spark plugs first. If problem persist, then one or more coils are gone.
Old Apr 28, 2012 | 08:05 PM
Laevateinn's Avatar
Check the freeze data for the code. check compression and spark too.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
dcardello
Sep 3, 2015 11:44 PM
