Junk Yard rear axle from a 96 I30 on my 97 SE and now its humming
Old Apr 29, 2012 | 11:02 PM
joemax89's Avatar
So my rear axle basically snapped last week, the passenger side arm that bold to frame snapped off. I got an axle from a 96 I30 at the local pick a part and put it on, after about 3-4 miles of driving it starting vibrating or humming and if i pressed brakes it stopped and it also stopped on its own. Its random tho, it comes and goes and probably only does it less then 5% of the time. I think it may be the bearings because the axle sat in the JY for a while and maybe dried up. I also replaced rear calipers and shocks while i had it all apart.
Any thoughts?
Old Apr 30, 2012 | 07:17 AM
njmaxseltd's Avatar
Did you spin the hub to check if it was smooth before you loaded it with brake components? That would have made it easy to detect a bad bearing.
Being it stops when you step on the brakes might also point to the brakes as the cause.
Old Apr 30, 2012 | 07:25 AM
joemax89's Avatar
Ya it spun just fine before I put it all together, I was thinking when you apply the brakes the car tilts forward just a little and takes weight off the rear end making it stop. I was ruining about swapping out the bearings with the ones off my old axle just to see before I bought new ones.
Old Apr 30, 2012 | 07:26 AM
joemax89's Avatar
Dang phone, thinking not ruining
Old Apr 30, 2012 | 03:34 PM
tsheffler's Avatar
His much did the junkyard charge u if u don't mind me Askin...I'm about to replace mine cuz I think its bent..( toe issues) . And was it a beotch to pull in a jy?
Old Apr 30, 2012 | 07:41 PM
joemax89's Avatar
It was a pick a part or whatever and it was only
$60 and I actually pulled 2. I pulled one off a maxima that had rust on it, took me 90 min, then I was coming back with a wheel barrow I passed an I30 that had a clean axle and I pulled that one in 30 min. It was actually easy, cars are lifted up, and the wheels are off. I also found a seat out of a different car and sat on it and floor mats to lay on. Also a tip, break loose all the big bolts first, much easier then trying to break them loose when its loose and hanging there. I also brought my little 12v drill with a 3/8ths bit so after I broke stuff loose I was able to zip them off.
I can't figure out tho if my vibrating is coming from my brakes or bearings, it does it low speeds and around 30-40 mph and with how loud it is at under 5mph I can't see the bearing doing that. I think maybe the axle breaking and the e brake getting yanked maybe tweaked my rotor.
erictown
Aug 20, 2015 08:01 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 12, 2015 01:54 AM
MikesChevelle
Aug 6, 2015 11:36 AM
BassAddictJ
Aug 4, 2015 11:38 AM
