So there's this hole in my 00vi...advice .Org'ers
Old Apr 30, 2012 | 01:02 PM
J_MAxxX's Avatar
Today i had the chance to take a picture of this, i got this about a month ago, but i still cant figure out how to plug it since i cant obviously weld it shut. i got this at a junkyard, it was already off when i checked the max out, the previous person just took the LIM. & i guess he broke off the break booster hose plug . So i can't progress with my 00vi swap until i can get this plugged. any advice on how to plug it?
Old Apr 30, 2012 | 01:53 PM
RA030726's Avatar
I'm nutty for Nissans
Plastic weld or JB weld, as long as you're not boosted it will hold if prepped right.
Old Apr 30, 2012 | 05:22 PM
tigersharkdude's Avatar
upside down gatorade cap JB welded in the hole and painted black? The mustang guys do that
Old Apr 30, 2012 | 05:41 PM
carsnwomen91's Avatar
shadyonedeath covers this in his write up http://forums.maxima.org/all-motor/5...1999-se-l.html
Old Apr 30, 2012 | 05:43 PM
what?? there's supposed to be a nipple sticking out of it for the brake booster line.
Old Apr 30, 2012 | 05:49 PM
hes asking how to plug the hole, not whats supposed to be there..
Old Apr 30, 2012 | 05:50 PM
nsnrider's Avatar
exactly what he said^^^
if you don't have the broken off piece then you might have to plastic weld it, then drill and tap a fitting into it or try gluing a fitting straight into that for the brake booster line.
Old Apr 30, 2012 | 05:57 PM
ya i got that part. check the link i posted, it deals with this exact situation. your idea with the gatorade cap is pretty good to cap the whole but why block it off when the brake booster line hooks up right there? all you would need to do after the gatorade cap is drill a hole and mount an appropriate sized nipple so you can hook up the brake booster line.
Old May 1, 2012 | 04:31 PM
J_MAxxX's Avatar
I'll get on it as soon as i can, thanks for the input fellas. pics will be up
Old May 1, 2012 | 06:59 PM
wirelessdude04's Avatar
Gatorade cap sounds like a good idea make sure you put rtv around it before sealing it up
Old May 15, 2012 | 12:08 PM
shadyonedeath's Avatar
rubber cork. :P
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
max ride 41
Sep 17, 2015 06:17 PM
