Tune up
Old May 2, 2012 | 06:11 PM
maxine1999's Avatar
Tune up
My max has 130k on her 99 auto and was wondering what are good things to replace to have maximum power & mpg. I want to Keep this engine running mint as possible. Plan on bringing her in to get a tune up. What things should I replace?
Old May 2, 2012 | 06:20 PM
bksmax11203's Avatar
Spark plugs with NGK go platinum part number 7090 if I'm not mistaken, air filter, fuel filter, oil, sea foam in crank case, fuel tank and intake manifold. That should take care of the tune up aspect of things. If you want more power with out the boost, Obx v2 5.5 headers, dek swap with egr delete, light weight pulley that's the same size as factory.
Old May 2, 2012 | 06:26 PM
maxine1999's Avatar
Air filters clean. K&N drop in. Oil is good to I use 5w30 mobil 1 synthetic extended performance. And what about the fuel tank and intake manifold? & what does spArk plugs help do?
Old May 2, 2012 | 06:53 PM
Don't forget other fluid jobs.
Old May 2, 2012 | 06:55 PM
maxine1999's Avatar
Like? Ik tranny fluids clean coolant is clean too
Old May 2, 2012 | 06:56 PM
N3SQV's Avatar
Sea Foam for the tank and intake.
Spark plugs ignite the mixture. After time the gap gets too big.
Old May 2, 2012 | 07:07 PM
maxine1999's Avatar
Oh alright how much do you think a mechanic would charge me to go all spark plugs and fuel filter?
Old May 2, 2012 | 07:50 PM
felorojas14's Avatar
Pcv valve...
Old May 2, 2012 | 08:06 PM
He should charge you 1 hr at whatever rate is posted on his wall. Shops vary, so call around.
Be careful, on one of my Maxima's I bought, the previous owner gave me a receipt which showed that he paid 3hr of time for a sparkplug and coilpack change...highway robbery.
In all honesty though, if you have basic tools, you could be doing all the maintenance yourself. You'll save a ton of money on labor.
Old May 3, 2012 | 07:10 AM
maxine1999's Avatar
Cool, thanks
Old May 3, 2012 | 07:36 AM
maxgtr2000's Avatar
KH3 by popular demand
You should have an extra set of coilpacks handy since those are infamous on 99s.
Old May 3, 2012 | 07:51 AM
MAXIMA_STYLE's Avatar
No joke man.. spark plugs are easy as pie to change on these cars... the cover under the hood with the nissan writing on it has the coils and plugs under it...thats a 5 minute job...the back are slightly harder.only due to limited space but shouldnt take no more than 35 minutes
Old May 3, 2012 | 10:04 AM
maxine1999's Avatar
Word, does it make a difference on my engine if i replace my coil packs? i know i have a new one on cycl. 2 from a misfire due to water.
Old May 3, 2012 | 10:07 AM
maxine1999's Avatar
Thinking about ordering spark plugs off ebay or amazon and have a mechanic put them on. I just don't mess with fixing my car myself. I rather just pay the labor, don't have patience for it.
Old May 3, 2012 | 10:11 AM
maxine1999's Avatar
Can anyone give me a website to get spark plugs off of and fuel filter? Im trying to buy the best one. And do mechanics due seafoam in there shops? I never seen a mechanic do it with all the smoke they cause and what not but i know it's def. worth it. It's safe for a engine with 130k on it right?
Old May 3, 2012 | 05:21 PM
eddie982's Avatar
How old are you, if you don't mind me asking?
Old May 3, 2012 | 05:50 PM
maxine1999's Avatar
18 why
Old May 25, 2012 | 10:31 AM
jayeyeMax's Avatar
18 why
well i was going to ask the same thing.
first i wouldnt buy spark plugs online, this is why stores are running out of business lol
go to autozone or pepboys or stores like that ask the guy behind the counter he will help you with everything you need for a tuneup.
dont know how to change spark plugs? search
Old May 25, 2012 | 10:41 AM
ShocknAwe's Avatar
As long as you get NGK you should be fine. You dont need to get the cheapest ones and if you dont like maintenance like you said you should get the Iridium ones. THe most expensive but they last the longest as well. DO NOT SEAFOAM YOUR CAR as others suggested, it can cause alot more problems than it fixes. Coils are expensive but if you have the money then go to the dealer and get all new ones, don't get aftermarket as those fail with great frequency. An oil change is obvious. I would also change out your O2 sensors as well as your knock sensor. Drain a couple of quarts from your tranny and replace with new Nissan Matic-D that you can get from the dealer. Lastly, flush your radiator. DO NOT hook it up to a machine, just get the bottle from the auto parts store and do it that way. Im sure im leaving a few things out but if you do all of this then your car should run like new and you should regain quite a bit of your lost HP.
Old May 25, 2012 | 05:44 PM
maxine1999's Avatar
Alright cool, i got the NGK plugs iridium runs so much smoother now. My spark plugs were toast. And why should i replace my 02 sensor?
Old May 25, 2012 | 08:20 PM
asand1's Avatar
They monitor the amount of oxygen in your exhaust and tell the ECU how much fuel to add/subtract. New ones MIGHT be more sensitive than your old ones and allow you to run better. If you don't have a check engine light on, then don't worry about them.
Old May 25, 2012 | 09:25 PM
Stonelove670's Avatar
I get my plugs at sparkplugs.com
Old May 25, 2012 | 09:41 PM
Gil's03Max's Avatar
No need to change o2 sensors or knock sensor, if there was something wrong with them you'd get an SES light. The old saying "if it aint broke don't fix it" works wonders, i know a lot of people that replace parts that are fine and end up with a problem on their hands from changing a part that worked as it should.
Old May 25, 2012 | 09:48 PM
CrazxyDominican's Avatar
I was comparing prices with autozone.. and sparkplugs.com overcharges and your then you have to pay for shipping.. save yourself 30 to 40 bucks and goto a store.
Old May 26, 2012 | 10:10 AM
maxine1999's Avatar
Thanks for the info guys.. What do you guys recommend best ride quality, coils for 4th gens?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Maxboy23
Sep 4, 2015 06:04 PM
