does anyone know what this wire is?
Old May 9, 2012 | 12:23 PM
styliztik's Avatar
it's the single black wire that connects on top of the a/c compressor. the first time I changed my alternator I went under and started unbolting and until I got the alternator out. and when I pulled the a/c compressor down I ripped the wire out. the plastic connectors were still connected, I just pulled the wire out of the connector. what does this wire do? and how can I fix it? I'm assuming it's power for it somehow. and it's started to approach 100 degrees now so I need my ac lol.
I can upload pics if need be.
Old May 9, 2012 | 12:38 PM
ShocknAwe's Avatar
pics would help. Test with multi meter and see if it is indeed power
Old May 9, 2012 | 01:41 PM
2brosgixxer's Avatar
This post confuses me. It seems you know where the wire came from, the compressor, so why not just plug it/splice back in where it goes? Edit: who cares what the wire does? It makes your ac work...plug it back in where it goes and be done with it
Old May 9, 2012 | 01:55 PM
BenL's Avatar
I believe we're talking about the connector for the field coil (E41 on FSM HA-43 [Manual]/HA-93 [Auto]), I just went out and looked at mine and it looks like that's what it is (based on location and it being single-wire).
As for fixing it, you can try to force the wire back into the connector (not very secure, but may work for a while), you can get a junkyard connector and just splice it in, or you can repair the connector.
Old May 9, 2012 | 07:52 PM
Trini Boom's Avatar
Definitely the power wire to engage your A/C compressor. Gonna have to get it repaired somehow.
Old May 9, 2012 | 11:29 PM
styliztik's Avatar
I was unsure because when the wire is unplugged, and I turn on the ac, I can hear it kick on, the rpms drop down a little for a split second, and I can see a small voltage drop but then it goes back up. but it didn't blow cold. I plugged it back in when I went to work today, and the ac worked, but after I hit the first speed bump down my street, it came undone and said f it. lol
Old May 10, 2012 | 04:23 AM
^^^ gotta love speed bumps at least you know where it goes and that it makes your ac work. Good luck.
Old May 11, 2012 | 10:03 AM
clint240sx's Avatar
def power source for AC, problem found, now time for fix
Old May 11, 2012 | 10:06 AM
GGENIUS's Avatar
its as easy as junkyard, shrink tube, heat gun, and some electrical tape because you never leave bare wires hanging around.
Old May 12, 2012 | 07:39 AM
JAY BLADE's Avatar
your wire too activate your compressor clutch
Old May 12, 2012 | 10:27 AM
moNYtx's Avatar
Jus get one new connection an plug it back.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
