Car Idle and Ignition System
Old May 11, 2012 | 07:59 AM
JAmerican's Avatar
Could someone tell me if my car idle sounds as it should. Still a noob at detecting if my car has issues from the sound it puts out.
http://youtu.be/zNPHM6_BBDs
I changed my spark plugs as can be seen here...
ENGINE FRONT (facing car) - LEFT, MIDDLE, RIGHT
ENGINE REAR (facing car) - LEFT, MIDDLE, RIGHT
Anyone know why my REAR LEFT spark plug looks like that? Also, based on the Haynes manual, my plugs being white at the tips means that they are running hot. My coolant level is low but not enough for the thermostat to increase passed the center point.
Anyone know what this brown stuff on the coil pack insulation is?
Old May 11, 2012 | 09:00 AM
asand1's Avatar
Looks like it could BA dried dielectric grease.
Old May 11, 2012 | 12:41 PM
njmaxseltd's Avatar
Plug tips look perfect.
Don't worry about the brown stuff.
Sounds like a normal VQ to me.
Old May 11, 2012 | 03:45 PM
DennisMik's Avatar
Other than someone replaced 4 of the 6 spark plugs at one time, the engine sounds good. The rear left plug and rear middle plug are different from the other 4. But I see in the one photo a brand new plug on the right side, so I'm assuming you changed the plugs. So the old plugs don't matter any more.
Old May 13, 2012 | 06:58 PM
JAmerican's Avatar
All plugs were the same ones recommended by Nissan FSM as well as I replaced all 6 with new plugs. The old plugs had the correct gaps still. The rear left plug (as indicated above) had oil on the threads, from a previous oil leak I assume. The leak has been fixed a long time ago and the tips didn't have the leak so I assume it was burnt off.
Old May 13, 2012 | 08:12 PM
wirelessdude04's Avatar
Honestly sounds fine. Watched the video twice. Brown studs is just gunk from people old. Change your plugs again maybe use some injector cleaner or seafoam honestly best bet
Old May 13, 2012 | 08:14 PM
Honestly sounds fine. Watched the video twice. Brown stuff is just gunk from being old. Change your plugs again maybe use some injector cleaner or seafoam honestly best bet
Old May 14, 2012 | 06:40 AM
JAmerican's Avatar
Did a 316 Mile Trip and got 30.8 MPG! I love this car. I use 93 octane only.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
maxima297
Aug 3, 2015 12:50 PM
