Oil light flicker......
Old May 15, 2012 | 07:37 PM
Boothers96's Avatar
So the past few mornings i go to start up the car and the oil light flickers 3 times and goes off and stays off. Oil level is perfect 5w30 mobile1 synthetic. Just wondering if i need to have mechanic test oil pressure. Not really sure where to start checking things out....
Im pretty urgent with this only because im moving 800 miles away next week and i want to be sure this things getting proper oil pressure so im not screwed in the middle on nowhere.....
Old May 15, 2012 | 07:44 PM
Trini Boom's Avatar
Personally, I don't think its necessary and you should be fine as long as you did your maintenance. How long in seconds does it take from beginning to end for all the flickers?
Old May 15, 2012 | 07:53 PM
Boothers96's Avatar
1 at most....its like: flick, flick-flick.....and then off. so ya....maybe i should switch to 10w since its gettin hotter out? would cleaning the strainer help?
maybe ill make a vid of it
Old May 15, 2012 | 08:00 PM
Kuhn_man's Avatar
changing to 10w isnt going to help even the owners manuel says it may flicker upon start up mine does the same thing and has been sence i owned the car. theres nothing to worry about as long as it doesn keep doing it while its running...if ur oil level is ok than i wouldnt worry about it ...like i said even the owners manual says it might flicker for a sec or two when starting now if it was doing it while u were driving than there would be an issue
Old May 15, 2012 | 08:01 PM
2brosgixxer's Avatar
Oil pressure switch. It's on the rear of the lower oil pan.
Old May 15, 2012 | 09:09 PM
Kuhn_man's Avatar
if it was his oil pressure switch than it would be on all the time
Old May 15, 2012 | 11:19 PM
Maybe...I am pretty sure infinimax96 just had this same problem and he solved it by replacing the oil pressure sensor switch. Here's his thread...post #9 he says he replaced the sensor and no problems.
http://forums.maxima.org/4th-generat...oil-light.html
Edit: but I guess his was flickering while driving...but still, it was not on constantly and replacing the switch worked for him. just a place to start I guess.
Old May 16, 2012 | 12:06 AM
TravisCadello's Avatar
maybe oil pump bout to go out.
Old May 16, 2012 | 12:30 AM
Kuhn_man's Avatar
very true, i see your point
mines done it every start up for about a second for the pas 6 years and 70 thousand miles, its old yes but like ive mentioned before even the owners manual says its ok if the light flickers for a second or so upon start up...ill look it up and tell you what page its on if you would like me to
Old May 16, 2012 | 12:39 AM
Boothers96's Avatar
I think ill try replacing the switch next oil change n switch to 10w30 synthetic.....ive read oil pumps r rarely faulty.....
Old May 16, 2012 | 12:48 AM
A number of people have had this problem...I just did a search and found this thread http://forums.maxima.org/4th-generat...-start-up.html
I think as long as you are not hearing any other noises/rattles AND it only does it upon start up, you are probably OK.
1 1/16 deep socket to get it out cant hurt anything to change it, its only a $10 part. I changed mine and the damn thing was not even screwed in all the way.
Old May 16, 2012 | 07:55 AM
infinimax96's Avatar
That's correct. It would also flicker on start up and sometimes on idle. It depends on if I was parked on any inclines. After replacing the sensor, bam haven't had an oil light since.
The sensor is cheap and took like 5 mins to change, 10 min with an oil change. You don't have to change the oil, mine just needed a change.
Old May 22, 2012 | 05:21 PM
Boothers96's Avatar
Ok so today I did the oil change and oil pressure switch....i went under to unplug it and it was barely hanging on.....
wth? i wonder how long the plug was snapped lol....anywho yall were right, the oem one was 1 1/16" deep to get it out but the one i replaced it with was only 3/4" autozone duralast. also switched to 10w mobile one synthetic and genuine nissan filter. ill report tomorrow n let you know if the flicker is gone.
thanks again!
mvm062
Nov 30, 2020 09:00 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
