Crankshaft removal engine locked up
Old May 18, 2012 | 02:58 PM
Brianrex's Avatar
Ok I have a 95 vq30de. I'm wanting to rebuild it but a main bearing is locked up like bad I can't crank engine at all I have bottom end undone I just need a bit of help on how to remove crank while engine is locked up plz and thank you
Old May 18, 2012 | 07:30 PM
njmaxseltd's Avatar
Remove the bearing caps???
Old May 18, 2012 | 10:48 PM
Brianrex's Avatar
Done did it still will not turn the torque converter and fly wheel r still on i have no clue how to get them off with out turning crank even then im lost how to get crank out dE
Old May 19, 2012 | 04:49 AM
Kevlo911's Avatar
Kevlo for President
remove the timing chain off it, remove the tensioner
Old May 19, 2012 | 08:28 AM
Kuhn_man's Avatar
your going to need a puller for it, but remove everything that touched the crankshaft and even then when i rebuilt mine i still had to take a rubber mallot and hit the crank to kind of "pop" it out, but if yours is seized than thats probly what your going to have to do, give it extra encouragement to come out lol , also take the flywheel and torque converter off it will help, you might have left one of the caps on
Old May 19, 2012 | 08:55 AM
asand1's Avatar
Are the engine and trans still mated? Trying to understand the problem here.
Old May 19, 2012 | 10:44 AM
Brianrex's Avatar
No the engine and transmission is not mated. But I can't turn flywheel to got bolts out to remove it.
Old May 19, 2012 | 11:04 AM
Brianrex's Avatar
Taking timing chain cover off now. Any thing I should kno?
Old May 19, 2012 | 04:53 PM
Kuhn_man's Avatar
what have you all taken off
mvm062
Nov 30, 2020 09:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
lowpost99
Sep 8, 2015 05:06 AM
