Spacers on stock wheels?
Old May 18, 2012 | 03:43 PM
illmaticmax's Avatar
Hey guys, new here. I tried searching for this topic, couldn't find, lock if one does exist.
I have a 1998, and just put in Tokico shocks and springs.
Was wondering if it is possible to put spacers on the stock wheels?
Old May 18, 2012 | 04:04 PM
Snypa's Avatar
yes ^^
Old May 18, 2012 | 04:33 PM
Thanks, and just to clarify these are the SE 16" stocks.
Old May 18, 2012 | 04:47 PM
Amerikaner83's Avatar
Oh yeah you won't have a problem. If you go more than like 10mm or so I think it is, you want to get longer wheel lugs, or a lug adaptor
Old May 18, 2012 | 05:39 PM
Also should probably mention I am looking for built in stud spacers for the stocks, still should be fine?
Old May 18, 2012 | 08:38 PM
I've got spacers on my sawblades now with no issues. Got 20mm up front and 25mm in the rear and it's still a little sunk but I'm not going higher than that (spacers wise).
Old May 18, 2012 | 08:44 PM
ShocknAwe's Avatar
Its possible of course but I would be careful which ones you get as most out there are very crappy. H&R is my recommendation. Trying to get a good stance with stock wheels is a futile effort however.
Old May 18, 2012 | 10:15 PM
Thanks for the input guys.
Old May 19, 2012 | 10:56 AM
GGENIUS's Avatar
i was running 25mm ebay spacers on my sawblades and never had a problem. except for putting added stress on my suspension.
Old May 19, 2012 | 11:57 AM
I forgot to mention that I'm running eBay spacers as well with no issues.
Old May 19, 2012 | 12:12 PM
GGENIUS's Avatar
no way in hell id run them on my heavy *** 18s tho.
Old May 19, 2012 | 12:15 PM
99SE-L5SPEED's Avatar
what does the spacers do for the ride i have a 99 se 5 speed and the front pass side hits hard i have tokiko illumana set up with tokiko lowering springs dose it need to be spaced out need help o and i did put in a new sturt on that side same one right out the box same sh it
Old May 19, 2012 | 12:17 PM
GGENIUS's Avatar
spacers are used to help your wheel clear other parts, and for adjusting wheel gap.
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 8, 2015 11:02 PM
adamgalazka
Sep 8, 2015 01:27 PM
Maxboy23
Sep 4, 2015 06:04 PM
