Vibration/ Suspension Woes
Old May 20, 2012 | 07:50 PM
Thaboywonder6588's Avatar
Ok... So I Bought 4 Used Tires To Temporarily To Put On My Car Until I Get A Brand New Set And Had Them Mounted And "Balanced". Now When I Hop On I-95 And Attempt To Drive Over 60 mph The Steering Wheel Shakes As Does The Pedal When I'm Accelerating. I Take It To A Shop To Get The Wheels Aligned. Before Guy Does So, He Tells Me That I Have A Bad Outer Tie Rod. Could This Be The Cause Of Vibration Problem? Also Tells Me Axle Will Need Replacing Soon. I Figured Since I'm Going To Have Such Area Worked On, Should I Just Replace Both Axles, Inner & Outer Tie Rods Before I Take It To Get Aligned? What Else Should Be Replaced Suspension Wise?
Old May 20, 2012 | 08:25 PM
Trini Boom's Avatar
Check lower control arm also. Don't know if you will have the funds to replace all at once.
Old May 20, 2012 | 08:54 PM
Specific Brand For Lower Control Arms?
Old May 20, 2012 | 09:07 PM
asand1's Avatar
Did it shake before swapping tires? Probably have one out of round. Try rotating front to back.
Old May 21, 2012 | 04:26 AM
It Was Shaking But Not As Bad... It Must Be Added That None Of The 4 Tires Are The Same Brand
Old May 21, 2012 | 07:45 AM
csam's Avatar
Yes, bad tie rod will cause shaking. Different brands of tires will not, but one out of round, or out of ballance certainly will. Balance is easy to fix, control arms and tie rods are a little more involved.
How many miles on your car?
Old May 21, 2012 | 12:01 PM
Quickywd01's Avatar
http://www.ebay.com/itm/95-99-Nissan...3105e6&vxp=mtr
Old May 21, 2012 | 06:20 PM
153k
Old May 21, 2012 | 06:22 PM
Definitely Appreciated... It's Got Everything Needed
Old May 24, 2012 | 06:11 AM
http://www.fcpimport.com/products/ni...kit-maxima-sk1
Anyone Ever Order From Here?
Old May 24, 2012 | 06:13 AM
AznRyan's Avatar
Why do people capitalize the first letter of every single word? >_>
AznRyan's Avatar
Originally Posted by Thaboywonder6588
I haven't
Old May 24, 2012 | 06:17 PM
atriuum's Avatar
I had a 4 set of goodyear, with the unidirectional tread for water channeling. I had them on a long time, without rotating. They became a LOUD set of tires. When I finally put on a new set, I could not believe how silent it was in the cabin, and the max isn't all that sound-dampened to begin with...
Point is, bad tires can make some noise. And it's more about the shape than tread.
Old May 24, 2012 | 09:05 PM
Because Everything I Say Is Important
Apr 16, 2020 05:15 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
