door courtesy light not working, help!
Old May 22, 2012 | 06:23 PM
al7601's Avatar
I did something stupid today using a screw driver to take the bulb out and I must of shorted it out because now its not working. Tried different bulbs, everything else still works, window switch works, the passenger side still lights, fuse is good too. Where do I go?
I tried searching and some say to re. place the window switch and some say the bcm but I haven't seen a confirmed solution. Also, I noticed eBay has the switches cheap in an off color bezel, can I swap the bezel if need be? Thanks!
Old May 23, 2012 | 06:55 PM
al7601's Avatar
Bump, not one reply?
Old May 23, 2012 | 07:00 PM
Shift_A32B's Avatar
I had the exact same problem....I've been living with it for months.
Old May 23, 2012 | 07:48 PM
DennisMik's Avatar
If the light in the other door works, then it is the window switch in the door. If neither door works, it is probably the BCM.
As far as the Ebay switch goes, you won't know if you can swap it into the Nissan bezel until you buy it and have it in your hands. It might be shaped differently, maybe not.
Old May 23, 2012 | 08:01 PM
Amerikaner83's Avatar
if it's used nissan you can no problem swap out the trim bezel.
And iirc You asked this same question like last week.
Dennis Twohy
Oct 1, 2015 06:01 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Blackwind
Aug 5, 2015 06:35 PM
kjm900r
Aug 5, 2015 07:14 AM
