real bad shake
Old May 23, 2012 | 05:37 PM
ibracey's Avatar
real bad shake
the title says it mostly. i have an AT trans and after alittle bit of running while im stopped at a light its like shakes but when i put it in neutral it stops. i am just wondering what you all think it is. thank you for looking
Old May 23, 2012 | 06:08 PM
Amerikaner83's Avatar
probably the motor / tranny mounts going bad. How many miles on the car? It's normal if you have over 150K miles. The mounts break over time, do you have a hard shift from R to D or anything like that? Same issue.
Old May 23, 2012 | 06:10 PM
Try cleaning your TB/IACV.
Old May 23, 2012 | 06:51 PM
WesCTR's Avatar
this right here. sounds like a dirty iacv.
Old May 23, 2012 | 07:19 PM
Trini Boom's Avatar
A lot of possibilities here. Try what the other members posted above and report back.
Old May 23, 2012 | 07:21 PM
ibracey's Avatar
ok so im not to good with the whole shorting things yet but what is the iacv. and the car has 280xxx miles on it. no it doesnt shift hard from R to D. it just shakes when its in gear at a stop light but as soon as i knock it out of gear its fine
Old May 23, 2012 | 07:28 PM
Trini Boom's Avatar
IACV (Idle Air Control Valve). It is located towards the rear of the engine with a pink, purple, brown, and grey harness. Three 12mm bolts hold it in place. Rewmove and clean with TB (Throttle Body) cleaner.
Old May 23, 2012 | 07:31 PM
ibracey's Avatar
thank you very much and btw how hard is it to fix a knock sensor 1 circuit malfunction and a manifold absolute pressure/barometric pressure circuit malfunction?
Old May 24, 2012 | 05:01 AM
njmaxseltd's Avatar
Bad mounts will not cause a shake.
The IACV only controls the idle speed, not how smooth it idles.
The shake might be caused by a misfire.
Is the check engine light on?
Old May 24, 2012 | 09:28 AM
Snypa's Avatar
I call bad mounts too.
Old May 24, 2012 | 09:34 AM
Goodspeed91's Avatar
mounts have bushings or rubber in them to help fight the vibration to ensure a smooth ride. i agree with mounts should be changed either way.
Old May 24, 2012 | 02:31 PM
ibracey's Avatar
yea it is but its showing a knock sensor and something else
Old May 24, 2012 | 02:53 PM
tigersharkdude's Avatar
could that something else be a Cylinder X misfire or P1320? Sounds like a misfire to me since you said it goes away when you put in neutral
Old May 24, 2012 | 04:20 PM
ibracey's Avatar
the two codes i got are p1105 which is manifold absolute pressure/barometric pressure circuit malfunction and code p0325 which is knock sensor 1 circuit malfunction (bank 1 or single sensor)
Old May 24, 2012 | 04:36 PM
SNIFFERPIVOTS's Avatar
i had this problem. I had a hose that goes to something...not sure what, but it had been cut by previous owner...vacuum leak essentially...fixed my in gear shake problem and my no VQ power until i reached 3k rpm. took me some time to find that. changed oil, CPS sensor , plugs,boots, fuel filter, TPS sensor, then paid $1 for a double barbed hose connector and now its gone.
Old May 24, 2012 | 04:54 PM
Reallyslowrio's Avatar
^^This gets my vote
Old May 24, 2012 | 06:07 PM
Trini Boom's Avatar
This is why I said here are lots of possibilities. From ignition coil, to park plug, to injector, to vacuum hose... But your statements are indeed true.
Old May 24, 2012 | 06:20 PM
I had misfire in multiple cylinders (P0300) that went away when I changed my plug boots, couldnt beleive the old boots, they ALL came out in pieces. I'm not sure if it was the boots or the CPS sensor that fixed it cuz I changed them at the same time. Either way the code went away.
HOKUSMAX
Nov 13, 2017 04:34 AM
Need help
23
Oct 2, 2015 08:56 AM
fx4five
Oct 1, 2015 04:58 AM
dshinn
Sep 26, 2015 08:07 PM
