Power steering pump replacement cost
Old May 26, 2012 | 09:56 AM
SPER's Avatar
I know there are a bunch of threads about power steering loss. But all of them are about the houses.
Today I went to hey my leak checked out and was told that the pump was bad and needed to be replaced.
I was told $356 for everything.
I told the dude not to do it because I want to double check with my other mechanic that I regularly go to. (came here for exhaust work, my mechanic doesn't do exhaust)
I'm still in the office waiting for the muffler to arrive and what not. But after doing a google search I found a new pump for $ 90.
Wanted to check and see if I'm getting screwed.
Old May 26, 2012 | 10:41 AM
Trini Boom's Avatar
If that's your OEM power steering pump and its not making any noises, don't change it. If its just leaking, only the return hose needs to be replaced (one with aluminum shield). Yet to see an OEM pump leak...
Old May 26, 2012 | 11:12 AM
SPER's Avatar
Thanks for your input. Yeah the pump isn't making any noise unless its low on fluid, than it makes the usual sound.
I assume it is the oem pump, car only has 120k.
I had a feeling that it wasn't the pump that's why I told the guy not to do the work. Definitely going to get a second opinion on monday from my mechanic.
Old May 26, 2012 | 01:37 PM
SPER's Avatar
I asked another worker there if they can double check and I was told that it WAS the high pressure hose. They told me anywhere from $150-200 to replace.
I think I will go to my regular guy for that.
Old May 26, 2012 | 04:07 PM
Trini Boom's Avatar
The hose itself is still good. Just replace the copper washer at $2/piece and you need 2 and problem solved.
Old May 26, 2012 | 07:29 PM
SPER's Avatar
O RLY?? How do you figure? I'm all for a $2 fix. Copper washer attached to what? The pump or the hose? Any Pics?
Old May 27, 2012 | 07:29 AM
Trini Boom's Avatar
Inspect the top part of the hose and you will see there are two copper washers on either side of the hose. Its the same connection at the pump so replace the copper washers and tighten and leak will stop.
Old Jun 18, 2012 | 03:01 AM
BLACKKILA.GTR's Avatar
im just curious on if this worked or not? would replacing the copper washers fix the problem?
Old Jun 25, 2012 | 03:27 PM
SPER's Avatar
I tried finding the copper washers, and gave up. I didn't know what the hell he was talking about. My PS is still leaking.
Old Jun 25, 2012 | 05:00 PM
asand1's Avatar
I think the high pressure hose has banjo fittings with copper washers, and the return line just has hose clamps and push onto nipples.
Old Jun 26, 2012 | 04:22 AM
Trini Boom's Avatar
I will see if I get under my car and get a pic of it for you soon.
vingodine
45
May 21, 2016 12:46 PM
02PearlSE
Oct 7, 2015 02:12 AM
maxinout93
Aug 20, 2015 02:17 AM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
