Cruise control
Old May 28, 2012 | 02:47 PM
vrscuteri's Avatar
Cruise control
Somtimes my cruise control works and some times it doesn't. Could this be the cruise control relay?
Old May 28, 2012 | 03:54 PM
CallMeThatOneGuy's Avatar
Mine used to do that. I just replaced the steering wheel controls for it and mine works fine now.
Old May 28, 2012 | 08:29 PM
Trini Boom's Avatar
Disassemble the controls and clean the contacts with a pencil eraser.
Old May 28, 2012 | 09:56 PM
asand1's Avatar
Could also be switches on the pedals.
Old May 29, 2012 | 08:19 AM
DennisMik's Avatar
All of the above plus many other possibilities. A vacuum leak to the Actuator mounted under the hoof on the firewall about center is another one.
Old May 29, 2012 | 08:37 AM
Phromethius's Avatar
Is there a write up for this? I've had this issue for a LONG time and just put it on the back burner and forgot about it. Everytime I go on a trip out of town though I miss it very much!
I was just going to pull an assembly from the Junkyard but i haven't got a chance to see how difficult/easy this could be.
Old May 29, 2012 | 12:17 PM
bobflood's Avatar
You should do some trouble shooting first; there are just too many possible places to throw parts at it.
Old May 29, 2012 | 05:46 PM
1cleanGLE's Avatar
if it is the controls. i do have a extra set
Old May 29, 2012 | 08:13 PM
Trini Boom's Avatar
I don't believe there is but when I replace my steering wheel, I may take a few pics to show it.
Old May 30, 2012 | 09:34 AM
I'm pretty sure it is the controls though since the master switch on the dashboard lights up green. however, the three buttons on the wheel have NO effect at all. No click, no engagement, holding down the set or resume button does nothing to maintain or increase speed.
Since that is where the process breaks down, should be a decent place to start right? I can check the pedal switches but if I can't get it to engage, I can't check to see if the brake pedal disengages.
I'll probably wait till Trini posts up some pics anyway though
Old May 30, 2012 | 09:50 AM
DennisMik's Avatar
There are no guarantees that the switches are the problem. There are a lot of conditions that have to be correct for the cruise control to engage. Check the continuity of the switch on the brake pedal. It may be intermittent.
Get the Nissan FSM for your year car. Then look up ASCD (Automatic Speed Control Device) and start checking.
http://boredmder.com/FSMs/Nissan/Maxima/
Old May 30, 2012 | 11:18 AM
MaxiNone's Avatar
i think i have a vac leak one of the hoses thats conect on some module thats bolted on the intake manifold, i hope that thats not my problem on the cruise not working :/ i guess i should try there first and hope that it fixes my CC engaging
Old May 30, 2012 | 11:34 AM
That one should be the EVAP purge volume control valve, two bolts right on top of the UIM. Brown connector? EVAP system, and not related to Cruise at all.
Unless I missed some sarcasm in that? /shrug
trying to be helpful with what i know though. And EVAP codes I know! still trying to clear those little bastards out.
Old May 31, 2012 | 01:47 PM
MaxiNone's Avatar
no sarcasm with that, vacumn was mentioned and the possible vacumn leak i have just came to mind. i'm just tired of trying to figuring out whats wrong and why i cant get it to work again :/
Old May 31, 2012 | 03:26 PM
DennisMik's Avatar
Several things have been suggested, but what have you checked and/or tested?
For example, when you press the switch on the dash, does the light in the instrument cluster illuminate?
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
