Factory Fog light alternative, inexpensive, looks good & brighter too.
Old May 28, 2012 | 11:45 PM
blackice0123's Avatar
I had a cracked lens on the passenger side when i got the car and i wanted to replace the light, but they're too pricey aside from pull-a-part (which i didn't want to bother with).
So I figured I would buy the same lights i had on 2 of my previous vehicles. I bought them at walmart, they're inexpensive (under $20) and very bright and I got them to mount up really easy using factory bracket mounting holes.
Here's the steps i did to install them.
1. Removed the oem fogs and brackets (will require you to remove some of the plastic shielding underneath the front bumper for easier access).
2. used the brackets that came with the new kit.
3. cut off and reused the oem fog light wire connectors on the new bulbs.
4. lined up new fogs by hand...easy.
something cool i figured out was that the new brackets bolt up to factory bolts holes and then just need to be slightly bent to point straight ahead. it was't hard. i just got everything installed, grabbed ahold of it with my hands and twisted it. I'm going to attempt to post a link to the pic of what's in the kit. Again, Walmart sells this kit.
Here's the link: http://blazer-international.com/Prod...res/RE774C.jpg
I haven't taken a pic of what it looks like on the 4th gen yet, but i will post one up tomorrow if possible. i like the way it looks.
Hopefully, this can help some people out who want to get rid of the factory fogs. These lights are brighter and have a better field angle and distance. I like how they light up more side-to-side as well. i always thought the oem fogs were too weak.
Old May 29, 2012 | 07:49 AM
Meh. Not bad I guess.
Old May 29, 2012 | 08:45 AM
GGENIUS's Avatar
oem fogs arent weak with a retro
Old May 29, 2012 | 09:06 PM
bksmax11203's Avatar
After reading this thread, i went and bought a set from walmart. They are very bright, but thats because they are crystal clear glass. But on the con side they CANNOT hold H.I.D.S. the housing gets extremely hot to the point where I couldnt hold them. Lights were only on for about 5 mins.
Old May 30, 2012 | 12:34 PM
2brosgixxer's Avatar
In for pics installed on the 4G...get some close ups too so we can see gaps etc please.
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
