LCA ES bushing life?
Old May 29, 2012 | 08:20 AM
97SEdriver's Avatar
this place is dead
I put in ES bushings maybe 4 years back, I'm getting told during my PA inspections that my LCA is loose and needs to be replaced.
Anyone have issues with ES LCA bushings not lasting very long?
Old May 29, 2012 | 10:44 AM
RA030726's Avatar
I'm nutty for Nissans
Yes. Last year I had to replace one of mine as well. I believe I installed them in 06. I also replaced the sway bar bushings again. Not a long lasting mod apparently.
Old May 29, 2012 | 11:25 AM
asand1's Avatar
They need to be greased occasionaly. How often to you grease them?
Old May 29, 2012 | 11:46 AM
97SEdriver's Avatar
this place is dead
um....since I used all the supplied grease to install them...that would be never
Old May 29, 2012 | 11:47 AM
97SEdriver's Avatar
this place is dead
So, how bad was it the 2nd time around? 1st time sort of sucked
Old May 29, 2012 | 12:11 PM
benjie's Avatar
Hi Asand1, could you define occasionally and what is the greasing process?
Old May 29, 2012 | 12:16 PM
wirelessdude04's Avatar
It all depends on how much you drive honestly. It is wear and tear but 4 year's still isnt that long.
Old May 29, 2012 | 01:10 PM
RA030726's Avatar
Easy as pie. I put anti seize on all the threads so everything came off like butter. Also since the bushings aren't pressed on like the OE, they just slide off the pins.
Old May 29, 2012 | 06:55 PM
asand1's Avatar
When they start squeking maybe, IDK. I would do it once a year. I had them on my fiero, but not currently on anything.factory bushings are bonded to the metal parts and flexes, es relies on the inner sleeve turning inside the bushing, hence the need for lube.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
