oil still leaking after ......
hello everyone , i just replaced rear valve gasket on my 97 maxima and still have oil burning off rear exhaust manifold. any ideas on what else it could be? the popular answer was valve cover gasket but no luck. thanks in advance
Im guessing is still the same thing. You can RTV the whole thing groove to not only keep it in place but prevent leaks. Once you tighten it up you must go back in a month or so and tighten it down again. Remember that
Same thing i did. Seal it really well.Install the cover and put more silicone in the grooves.
Several weeks after I replaced both rocker cover gaskets the front gasket started leaking around the dipstick. I just had to re-tighten those low-torqued bolts.
If the surfaces were cleaned well, you should be able to pass your hand at the back and feel the corner to see if your hand comes back with oil. THis will help you to verify if its still leaking or still burning off existing oil.
With these bolts requiring such little torque, 47 to 65 in/lb, they can loosen if given anything under that. My torque wrench cannot be set that low so I didn't give it enough during installation. Those front bolts around the dipstick were loose so they didn't break when I tightened them up again with ~60 in/lb. I did that over a year ago and there's been no leaking since then.
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
