Knock sensor wire
Old Jun 3, 2012 | 07:10 PM
bksmax11203's Avatar
Knock sensor wire
Ok so i believe for some reason my ecu isnt getting signal thru the knock sensor wire. Does anyone think it'll be ok if i ran a wire from the ks straight to the ecu?
Old Jun 3, 2012 | 08:36 PM
wirelessdude04's Avatar
No not a good idea. Is you CEL on?
Old Jun 3, 2012 | 08:39 PM
asand1's Avatar
Not ok. That wire is shielded for a reason. Have you checked the harness for continuity? What were the ohms? Did you install a new KS? Have you tried the resistor mod for testing purposes? What is the reason for thinking there is a problem? Any OTHER codes?
Old Jun 4, 2012 | 07:36 AM
Unfortunatly i dont have an ohm tester to check for continuity. I replaced the ks with two brand new ones from nissan. I also got a new harness. The only other code is the egr temp and an o2 sensor, but neither should cause the ecu to keep throwing the code. I ran my prev max with oovi, egr deleted n two out of three o2's with no problem. Also i didnt mean run it straight from the ks, i was gonna trace the two wires off the sub harness until they go into the one wire that goes to the ecu and tap in there.
Old Jun 4, 2012 | 09:19 AM
asand1's Avatar
Get one, youll need it.
Generally, this will throw a ghost KS code.
There is one wire from the ECU to the KS. the "second wire" is for the shield that runs the whole length, they never actually connect. If you go to the trouble of running a wire that probablyt wont work, It would really suck to find out it was due to the O2 and EGR temp the whole time. Fix the other codes first, then worry about the KS.
DennisMik's Avatar
If you want to work on today's cars, you need to get a multimeter. Measuring voltage and resistance is an everyday thing now. It is more necessary than a screwdriver. Bite the bullet and get one. For $20 - $25 you will get one that will last for years. If you get the $5 Radio shack special, those things are one time uses and you throw them away.
Old Jun 4, 2012 | 01:39 PM
Thanks everyone. Imma bite the bullet and get one. I have one but its in ny and im in pa smh. But how exactly would i use it to determine the ohms and continiuty? I never used one -__-
Old Jun 4, 2012 | 02:18 PM
Ok so after being bored in the house i took the advice n looked into the other codes for the egr temp sensor. Looked around the engine bay n saw that the ground wire for the sensor was broken off at the harness clip smdh. I fixed the wire n extended it. Cleared the codes n did a couple wot pulls. Car feels much better, and when i scanned it again no codes came up. Not even the o2. Keeping my fingers crossed though, but thanks again.. I still wanna learn about the multimeter though lmao.
Old Jun 4, 2012 | 04:24 PM
Yea should def have a multi meter. Its basic tool involved in troubleshooting electrial problems
Old Jun 4, 2012 | 05:58 PM
maxinout93's Avatar
I got a multimeter for $5 from harbor freight tools, sometimes they have good deals if you live near one.
Old Jun 4, 2012 | 06:04 PM
DennisMik's Avatar
For continuity and resistance (ohms), you use the meter the same way. Continuity is zero ohms, which is a short circuit. This means that there is nothing to stop or slow down the flow of electricity. A piece of wire will read zero ohms or short. Ohm is the unit of measurement to describe resistance to the flow of electricity.
To check for continuity or resistance, you set the meter to measure ohms. Then touch a wire connection (or lead or end - lots of ways to say it) with one of the meter probes and then touch another wire connection with the other meter probe. The meter will display how much resistance it has calculated.
You have to have an idea of what to expect the meter reading to be - what were you checking for? Zero ohms is good for a continuity test but bad if you were checking the resistance of one of your ignition coils.
If you have fuses blowing, you would be looking for a short. One way of testing for a short is touch one of the meter probes to a wire and the other meter probe to the car's chasis ground.
Old Jun 4, 2012 | 06:09 PM
DennisMik's Avatar
Harbor Freight is like the $5 Radio Shack special - plan on buying one every other time you need to use one. I bought a decent one (Fluke) back around 1972 and used it almost every day on the job. Lasted till about 2 years ago when I left it on the ground and ran over it.
Old Jun 5, 2012 | 06:37 AM
Thanks a lot dennis, that really answered many questions for me.
Old Jun 5, 2012 | 08:19 PM
Trini Boom's Avatar
I am still trying to figure out my issue and I did test for continuity on pins 1 and 2 and it is showing continuity. There is continuity from ECU to end of KS sub harness connector. What else should I do?
Old Jul 8, 2012 | 12:09 PM
Serlone's Avatar
I have a similar problem. Just the KS code comes up. KS is new but there is no current in wire leading to sensor. Any suggestions?
ballerchris510
Sep 23, 2015 08:46 PM
ballerchris510
Sep 11, 2015 05:29 PM
conansriver
Sep 11, 2015 10:26 AM
