03 Maxima 3.5 Tranny in 99 3.0?
Old Jun 4, 2012 | 08:03 PM
TravisCadello's Avatar
Just wondering cause im going on my third tranny and i race alot would this tranny be a stronger tranny and last longer since 3.0 dont make as much power?
Old Jun 4, 2012 | 08:17 PM
maxed_out_99's Avatar
3rd tranny?? WTF? dude i thought you were going to replace your solenoids?
a 00-01 trans will fit and there stronger. i dont think the mounts are the same for the 02-03
Old Jun 4, 2012 | 11:24 PM
whiteSE's Avatar
+1
the mounts are diffrent. but its been done before
Old Jun 5, 2012 | 05:36 AM
njmaxseltd's Avatar
No stock transmission is going to help you. They are not built to race with.
Old Jun 5, 2012 | 06:48 AM
max1008's Avatar
were these transmissions junk yard transmissions? Damn! I just one built from scratch and loving it.
Old Jun 5, 2012 | 11:50 AM
if you like to race your max i highly recommend a reprogramming kit
Old Jun 5, 2012 | 08:28 PM
Trini Boom's Avatar
Your third tranny man? They are autos which means you are slamming into gears? :metalmax:
Old Jun 5, 2012 | 10:21 PM
Fill Me In Please.....
Old Jun 5, 2012 | 10:25 PM
Well lets just say I Got a Factory FREAK and i love her and have had her a good amount of time now, Alls i got done is a y-pipe,cold air intake,drop,and Mobil 1 Oil And I Tie Up with a 06 Maxima 3.5 With Y-pipe,some synoid block off plate and few other mods along with apexi cat back.
So yea i race quite a bit but my friend says it cause the way i race it,i push it to the maxxx Right before redline switch it manually to 2nd and sometimes it hits the rev limiter on accident and on rolls only way i get the 06 is if i do a 20 roll put in neutral rev to 4000rpm and slam down into 1st i burn tires all thru first but still pull away from the 3.5....i know its All Hell on the tranny But I think i just need a 5 speed swap.
yes the tranny i put in few months ago was junk yard but only has 120k miles! Id like to know what i can do to toughen up the auto until i can swap 5 speed in it.
&& I call it a Factory Freak Cause Wife has a 95 and friend has a 97 and before i did Y pipe I beat both of their cars by like a bus link or 4 cars got my Ypipe and its just embarrassing what it does to them, i dont think the 99 did anything different but mine runs strong i got 245k miles on motor,they have 140 and 170 So leads me to think mine was deffentely properly broken in when new.
Old Jun 5, 2012 | 11:45 PM
schmellyfart's Avatar
Never heard that the 00-01 trannies are stronger. Have any proof?
Originally Posted by whiteSE
+1
6mt, yes the mounts are different. Auto, no the mounts are the same.
The automatic transmissions from 1995-2003 are the same.
Old Jun 6, 2012 | 06:30 AM
tigersharkdude's Avatar
Just figured out why you are on your 3rd trans. This is just SMH SMH SMH
Old Jun 6, 2012 | 06:50 AM
NmexMAX's Avatar
dot dot dot ...
^^^^^ Don't do that.
The only difference between the 95-99 and 00-03 is the final drive ratio. Many of us have pondered it's because of the taller tires on the 5th gens.
The reprogramming kit is slightly a miscommunication since nothing electronic is happening to illegitimately claim a "reprogram".
There are the age old TCM reprogram kits, but are unproven and outdated.
There's the Suprastick, but I think at your level, a VB mod or Trans Go kit is better suited for your needs.
I'm using 4th gen mounts on my 2003 currently.
Old Jun 6, 2012 | 10:14 AM
the reprogramming kit completely changes the way the trans shifts. it also increases the line pressures and shift pressures and makes the trans shift stronger and last longer
my car.
it takes everything i give it. my first 2 4th gen trannys couldnt take it and gave up on me
incorrect
the reprogramming kit is installed in the valvebody.
its called a reprogramming kit because it reprograms the valvebody. the valvebody controls the way the trans shifts not the tcm.
the tcm only reviews data and commands solenoids on and off with info givin by the valvebody. the valvebody is the brain.
the 5th gen trans is completely different the ratios are different because it came with more power the valve body is completely different and the fluid routing is different just about the only thing that is the same is the case because it was bolted to a 3.0 block
before i swapped in the 5th gen trans in to my max i did all my home work the valve bodys are not compatible the sloenoids had to be spliced in and alot of sh*t changed.
before the VI my car was a dog after the brake torque because it just didnt have enough power for the ratios.
heres a link with some info
http://transgoonline.com/products.ph...dcountview=Yes
travis,
FOR THE LOVE OF CHRIST DO NOT NEUTRAL DROP YOUR TRANS
Old Jun 6, 2012 | 10:34 AM
Neutral dropping to first at 4grand is retarded ...seriously there are no words for that stupidity
Old Jun 6, 2012 | 07:51 PM
yes, i told myself when i installed the last tranny i wouldnt do any Neautral Drops, But started addin bolt ons and got carried away and here i am again same boat....
I was thinkin, I drove her 120 miles today and when cold it will kill motor like the tranny is locked up when put in R or D and after awhile it will stop and finnally drive but slip and slam into last gear even if i floor it she barely moves along and come to a light its stuck in 4th gear and shuters and will shut motor off if i stop without putting into N...after 25 minutes shes GREAT for rest of day even doging it all down highway.
is it possible i got a clogged fluid filter or maybe the screens in the solynoids need to be cleaned? if so should i drop pan clean it all up or just go pay for a flush?
Lakersallday24
Jun 16, 2019 01:35 AM
Supragte
Aug 12, 2015 10:00 PM
sc10692
Aug 9, 2015 09:37 AM
altmycar
Aug 6, 2015 04:44 PM
Blackwind
Aug 5, 2015 06:35 PM
