Crazy Car
Old Jun 8, 2012 | 03:29 PM
CMP's Avatar
CMP
Crazy Car
Here's one for you, 95 maxima runs great after it warms up, But not before it dies as its warming up & the fans run twice for 10 sec's then it dies,It blows out a gas cloud & It will not restart until i remove the fuel pump fuse! (flooding I'm assuming) .After that It crank's up & runs fine, after i plug the fuse back in. Note this only happens as its warming up. No codes, no idle issues, 221 k miles Runs great just like the day i bought it.
Old Jun 8, 2012 | 04:35 PM
maxinout93's Avatar
If the fans turn on while its still cold, most likely its your coolant temp sensor. When i first got my max it did the same thing, would start right up idle and die, then both fans would come on at same time. Somtimes it would stay running until i pull off, then it would shut off again. There was no code for it that im aware of. But since i replaced the coolant temp sensor its been fine ever since.
Old Jun 8, 2012 | 04:50 PM
CMP's Avatar
CMP
Awesome! & thats the switch @ the upper radiator hose inlet.? 2 wire plug. I'm going to give that a shot, cheap part Thanks great site glad to be here.
Old Jun 9, 2012 | 12:51 PM
maxinout93's Avatar
Ok glad i could help
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JMag90
Aug 25, 2015 09:17 AM
beboski
Aug 16, 2015 05:23 PM
MikesChevelle
Aug 9, 2015 11:50 AM
