Cutting out
Old Jun 10, 2012 | 06:17 PM
vrscuteri's Avatar
Cutting out
97 maxima runs fine at 60. cuts out if you floor it. Any advice?
Runs fine if you dont push the peddle down to fast. If you give it to much gas quickly, it cuts out. Let up again and it smooths out.
Old Jun 10, 2012 | 07:35 PM
2brosgixxer's Avatar
Let's start with this...Is your check engine light on? By "cutting out" do you mean its logging down? Tune up Items all good...plugs, fuel filter, air filter etc?
Old Jun 10, 2012 | 07:52 PM
TravisCadello's Avatar
possible TPS Sensor.
Old Jun 10, 2012 | 08:52 PM
sanford7575's Avatar
This happened to my '92SE a few years back turned out to be the following...
TPS & MAF.
Old Jun 10, 2012 | 09:02 PM
Cuts out like a misfire? Explain.
Old Jun 10, 2012 | 10:06 PM
TPS & MAF.
+1 I was leaning toward MAF as well but he needs to explain a little more.
Old Jun 13, 2012 | 05:58 PM
vrscuteri's Avatar
Check engine light is not on. I mean it like stalls out. It is not skipping or misfireing.
It simply cuts totally off and on as if the coil wire was loose on an older type car. Has new fuel filter. Was at the garage for three weeks, but would not act up for him. The battery and alternater checked out fine.
Old Jun 13, 2012 | 06:00 PM
Have you ever cleaned your IACV or TB?
Old Jun 13, 2012 | 06:04 PM
WesCTR's Avatar
more than likely it's his maf.
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
