Clear Coating Rims
Clear Coating Rims
Has anyone removed and replaced the clear coat on the sawblade rim without painting them at the same time? Wondering if I can just re-clear coat them and if it will look okay?
Or should I paint the entire wheel silver first?
Just trying to clean them up a bit.
it entirely depends on the condition of your wheels now. if the clear is in tact its just dulled, you can sand and spray. but if theres oxidation, scratches, or the like, you need to sand it all down until the surface is smooth and flawless.
then you will probably need to spray a base. then clear on top of your color.
Not sure if you really want to repaint your wheels since OEM work is usually the best. But here are some links to a few posts I like on how people repaired and repainted their wheels, and their results are pretty good.
http://forums.maxima.org/tires-wheel...l?ref=esp-link
http://forums.maxima.org/detailing/6...l?ref=esp-link
Hopefully, you'll able to find your answer.
They were a mess, 232K miles was kind of hard on them! I already striped the old clear coat. Just wondering if I need to paint them or just clean them up best I can and re-clear coat.
I think I read most of those threads.
I am going to sell the car soon, so I just want them to look better. If i was going to keep it, I would just get new rims.
i would say get some 80 grit and go to town on them. also chips/curb rash is going to need an angle grinder or something similar. but as for the rest start with 80grit. once the imperfections are gone with the 80 switch to 180 and get all those 80 scratches out. by this time you will probably need to spray color unless you want the brushed metal look.
he wants to get rid of the imperfections and reclear them. polishing them is nice too but im just answering his questions. he already removed a bunch of clearcoat he said so even if he polishes now, they will surface rust.
naw...if he uses aircraft stripper to completely strip the rim of clear coat and wetsand them..starting from about 600/800 grit to 2000 grit, it'll be money and as long as he keeps them maintained theyll be fine
you should call it a day and buy my sawblades that i already mediablasted, sanded, and powdercoated 98% gloss black. and theyre already balanced, with relatively new tires.
I actually looked locally for some decent saw blades to just replace these with but didnt find anything.
I just want to get them looking better to sell the car. I think I will sand them down and see what they look like, then maybe paint them, but for sure clear coat them.
Thanks for the input guys!
i just paid a service to re-do 2 of my hyper silver wheels and i can tell you its not as easy as it looks. you really have to get the surface smooth and make sure you repaint them with a silver base before you re-clear them. with a pro it only took him an hour and a half, of course he had a compressor and blasted the wheels before repainting and re-clearing them. good luck
i only went that low to be safe because pics can be deceiving, and he said there were dark spots, which i know galvanization can be a ***** to get off sometimes. 600 is pretty fine to be doing metal prep with, especially if any of the scratches can be felt with your fingernail.
my post is just referring to polishing the wheel by hand btw
04-16-2020 05:15 AM
