steering wheel shake after changing axles & other problems
Old Jun 12, 2012 | 05:01 PM
zubi23's Avatar
Here's the thing: I just recently changed my axles and ball joints and now when i'm driving the steering wheel shakes when accelerating from 0 - 40mph. I don't know why it shakes but its been doing that after I've changed the axles. I took it back to the mechanic and he said its a combination of wheels, torque, problems with the sway bar, and since the car is lowered.
The shaking is really annoying and it still makes this random squeaky noise coming from the tires ( probably from my sway bar ). I don't know how much changing a sway bar costs & i was thinking of unlowering the car because my mechanic said that's having an effect on the struts and shocks and suspension, but then i would probably have to swap the shocks and struts which would cost alot of $$...
any ideas?
Old Jun 12, 2012 | 08:30 PM
thedwyer00's Avatar
Go get an alignment check. If you only developed this shake after swapping out the axles, chances are that the alignment got screwed up.
Old Jun 12, 2012 | 08:43 PM
Did you have a wheel alignment done afterwards?
Old Jun 13, 2012 | 06:35 AM
Snypa's Avatar
If all the above doesn't help... I heard motor mounts COULD be something to check into.
Old Jun 13, 2012 | 06:42 AM
CallMeThatOneGuy's Avatar
one of the axles you installed (most likely te passenger side) could have some play in it at the joints. you can check this by twisting it with your hands. If it has enough play, it will still make noise or possibly shake, like mine and your car do
HOKUSMAX
Nov 13, 2017 04:34 AM
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 11, 2015 12:53 PM
