Car turns off when radiator fan turns on
Old Jul 9, 2012 | 11:25 AM
ayobad's Avatar
When I started my car this morning, the car started fine but after one minute the radiator fan turned on and 10 seconds later the engine turns off.
I tried to turn on the engine but it hardly would start until I give it gas to get it started.
I just recently replaced fuel injector in cylinder 5.
Any suggestions.... I need help.
Posted from Maxima.org App for Android
Old Jul 9, 2012 | 11:37 AM
cashoit's Avatar
need more info. what year? AT or MT? miles? condition? replaced any parts?
Your issue can be the results of not having done a tuneup in awhile.
Clean the TB and MAF per how tos. Check your IACV per FSM
Old Jul 9, 2012 | 03:44 PM
Maxima_Joe's Avatar
4th Gen Parts King
Most likely ECTS.
Old Jul 9, 2012 | 04:46 PM
asand1's Avatar
Originally Posted by Maxima_Joe
Most likely ECTS.
This. The engine thinks its hot so the air/fuel ratio goes too lean and the fan kicks on. In the morning you need a richer A/F mix.
Old Jul 9, 2012 | 05:33 PM
ayobad's Avatar
I cleaned out the Idle air control valve and throttle body... I got two check light code 0103 which is engine coolant temperature sensor and 0304 which is knock Sensor.
The car runs great and it's 95 gle with 101000 miles
Old Jul 9, 2012 | 05:41 PM
2brosgixxer's Avatar
Dont worry about the KS until you take care of the other code for the ECTS like MaximaJoe said in the 3rd post.
Old Jul 9, 2012 | 05:58 PM
surban1's Avatar
fyi, if you're looking for a knock sensor, i'm selling original equipment genuine nissan knock sensors for $35.00 (which includes usps flat rate box shipping; add $2.00 if you want insurance) to org members. this is the absolute best price you'll find for a genuine nissan ks. here's the link to my ad in the 4th gen classifieds.
http://forums.maxima.org/4th-generat...0-shipped.html
Old Jul 9, 2012 | 06:02 PM
maxinout93's Avatar
It is your coolant temp sensor. My max did the same thing when i first bought it 2 months ago. Mine is a 95 auto gxe. It would start up and the fans would come on then die and refuse to start up again. Sometimes i would drive it a short distance and it would shut off while the fans were running. After i replaced the cts ive had no problems with it.
Old Jul 9, 2012 | 10:38 PM
ayobad's Avatar
Thanks guys.
I bought a Engine Coolant Temp Sensor for 25bucks from Autozone and it did the job....it was real easy to put on and only took 5 min.
CTS was the problem!!!
Thanks guys
Old Jul 10, 2012 | 07:28 PM
Trini Boom's Avatar
Originally Posted by ayobad
Thanks guys.
Thanks guys
Lakersallday24
Jun 16, 2019 01:35 AM
beboski
Aug 16, 2015 05:23 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
