a/c
Old Jul 21, 2012 | 11:56 PM
mpudgie's Avatar
a/c
hey guys i have a 96 my problem is i have no a/c i have no power going to the compressor i used a test light to see if i get any power and i get nothing do you think its the relay under the hood
Old Jul 22, 2012 | 01:52 AM
styliztik's Avatar
Check connections, wires, fuses, and relays. If you do that I can GUARANTEE you will find why it's not getting power.
/thread
Old Jul 22, 2012 | 07:04 AM
mpudgie's Avatar
How do i check the relays
Old Jul 22, 2012 | 08:28 AM
Trini Boom's Avatar
Swap it with another identical relay in the box and test again.
Old Jul 22, 2012 | 08:56 AM
mpudgie's Avatar
i just did did not work
Old Jul 22, 2012 | 09:20 AM
mpudgie's Avatar
can't fig it out on what it is everything looks good idk
Old Jul 22, 2012 | 11:06 AM
DennisMik's Avatar
There is a pressure sensor for the R134a refrigerant. If it has leaked out, the compressor won't run, preventing the compressor from destroying itself.
Old Jul 22, 2012 | 12:21 PM
Trini Boom's Avatar
^^This. Does it even have R134a in the system to begin with? Nothing will happen without this.
Old Jul 23, 2012 | 01:03 PM
mpudgie's Avatar
Thanks all this time i thought i had in it there but i guess not i got it to work i put some R134a but i think i need to get another one the one i got was the small can now should i get another small can or get the big can
Old Jul 23, 2012 | 01:35 PM
Quickywd01's Avatar
R-134a+ http://ecx.images-amazon.com/images/...500_SS500_.jpg
Old Jul 23, 2012 | 06:27 PM
http://forums.maxima.org/4th-generat...e-contest.html
Old Jul 23, 2012 | 07:28 PM
max ride 41's Avatar
ya know???
Old Jul 23, 2012 | 09:13 PM
Trini Boom's Avatar
Two 12oz cans is enough to charge system completely...
Old Jul 24, 2012 | 07:31 AM
GGENIUS's Avatar
each small can is 12oz. each car has its own specified level of r134a that youre supposed to fill it to. its usually documented on a label on the underside of the hood, and itll tell you the measurement in pounds. (for example when it says min .9 and max 1.4 you would fill it with 1.4 pounds of R134a from empty.)
Old Jul 26, 2012 | 04:15 PM
mpudgie's Avatar
There is a leek i have to change the a/c CONDENSER
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
