P0135 + P0155, replaced O2 sensors, still receiving error codes
Old Jul 30, 2012 | 11:10 PM
jigsaw's Avatar
So... I failed my emissions test and I was informed that (P0135: Bank 1 Sensor 1) and (P0135: Bank 2 Sensor 1) have failed heater circuits. Today I replaced both of the front O2 sensors with Bosch (the same ones that came on my car) and I am still receiving the same error.
During the installation, unplugged the battery and I reset the ecu numerous times in between starts. The car is idling nicely, but usually the code pops up the second or third time starting the car after resetting the ecu.
I am experienced with this repair, as this is the second time in 4 years that I have replaced the oxygen sensors. Also, I have not had issues passing emissions since the first 02 sensor instance. From what I have gathered, it appears that I need to:
1. Check the voltage coming from the wire harness. Which should be between 10v - 12v. http://troubleshootmyvehicle.com/gm/...sor_test_2.php
2. Clean the egr tube. http://forums.maxima.org/4th-generat...ing-p0400.html
3. Check for exhaust leaks using Seafoam. As any leaks will have smoke pouring from the location.
My tag will be expiring, so I will be riding the bus for +1 hour to my friend's house, where I will be doing the repairs. Is there anything else that I should check or try in addition to the steps above?
Thanks in advance for your help!
Old Jul 31, 2012 | 09:45 AM
jigsaw's Avatar
I realized that all I needed to do was check the 15A fuse next to the steering wheel and I would have saved myself a few hours of my time and $150. Problem solved and emissions passed. Check your fuses FIRST kids!
Old Jul 31, 2012 | 10:40 AM
speed racer's Avatar
are you serious. I'm getting both o2 sensors as well. Which fuse you needed replaced.
Old Jul 31, 2012 | 01:01 PM
bobflood's Avatar
Should be Fuse #31 - 15 amp for all 3 or 4 O2 sensor heater circuits.
Old Jan 5, 2014 | 11:46 AM
yanzhi's Avatar
this is useful for me because recently I am look for the information on o2 sensors.
Old Jan 5, 2014 | 11:51 AM
yanzhi's Avatar
good idea, I should check it also.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
