Electrical issue..
Old Aug 4, 2012 | 11:06 AM
nycspudz03's Avatar
Electrical issue..
My headlight fuses keep blowing. I switched the relay and it started working but now my dash instrument cluster doesn't work. THat fuse keeps blowing. Can someone point me in the right direction as to how to diagnose my issue
Old Aug 4, 2012 | 11:50 AM
hvyft's Avatar
sounds kinda like a ground or exposed wire
i hate these types of things, its like a neverending adventure haha
Old Aug 4, 2012 | 02:28 PM
DennisMik's Avatar
What relay did you actually swap? Was it the Theft Warning Relay? And with which relay did you swap it with?
Under normal conditions, the light switch on the steering column sends power directly to the headlamps, no relay involved. But if the alarm is set off, then the Theft Warning relay is used to make the high beams flash.
When you say the instrument cluster doesn't work, in what way doesn't it work? Is it that none of the gauges work or is it that the dashlights don't work? and which fuse is blowing? Look on the plastic fuse block and give me the fuse number.
Old Aug 4, 2012 | 03:25 PM
nycspudz03's Avatar
The entire cluster is dead. It only illuminates when the headlights are put on..but the rpm,odometer,gas gauge,etc are all out. Im not actually sure which relay I swapped out. But I know I swapped it with a relay of the same value.
Old Aug 4, 2012 | 08:50 PM
DennisMik's Avatar
What year is the car? You said you have a fuse blowing, which one is it? Is it number 13?
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
