Does rust and corrosion effect suspension
Old Aug 7, 2012 | 08:19 AM
zack97GLE's Avatar
Pardon for the newbie questions, but when we were doing the alternator underneath my newly aquired 97 Gle w/just under 70k I noticed quite a bit of rust on all the suspension parts mostly the lower control arms, stabilizers, and it is rust that you can pull of with your fingers . I also noticed the radiator support rust that I have seen mentioned here. Basically does rust weaken these suspension components, or is it a non issue?
Old Aug 7, 2012 | 08:41 AM
WesCTR's Avatar
the rust on the rad support = issue. it will get worse and it's definitely not something to ignore. the control arms are fine.
Old Aug 7, 2012 | 08:48 AM
zack97GLE's Avatar
Thanks, from what I can tell the rad. support rust is in the middle mainly by the bolts, does this actually hold the engine as well as the radiator? and is there some rust stopper or something to slow it down, how about that primer that is supossed to convert rust into a paintable surface
Old Aug 7, 2012 | 09:28 AM
tigersharkdude's Avatar
gonna need to buy a NEW OEM radiator core support. If you buy some junk off ebay or rockauto or autozone that thing will just break in a few months
Old Aug 7, 2012 | 02:01 PM
GGENIUS's Avatar
we need a sticky thread about the horrors of buying a cheap rad support and have all the pics of them broken after months of wear.
Old Aug 7, 2012 | 02:17 PM
Quickywd01's Avatar
Perfect example of when going cheap is NOT an option. Doing research is key.
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
uttadms31
Sep 30, 2015 05:24 AM
