Koolest Alarm Led!!!!
I was cruising along queens blvd ( in new york) aka blvd of death, and i passed by a few of those auto performance stores. I saw this guy that had his alarm LED integrated into his right altezza tail light
......HOW DID HE DO THAT!!!!! - i want it so bad - it looks so kool!
Geez ... only 15 minutes passed ... you're an impatient one, aren't you?
Probably took the altezza apart, slide the LED inside, taped it up or something and then resealed the altezzas, then ran the wires up to the alarm ... simple.
They sell kits...it includes the led and a rubber washer. You drill a hole, drop in the led and plug the hole. Eventually the rubber will wear away and you will have foggy lights...then blown lights...
Erik
Erik
Erik
Erik
Originally posted by ljl10
No doubt about that....
Don't crush the man's dream! Help him SEE the LIGHT!
LED installations are pretty easy to do. the hard part is running the wires and finding a good mounting spot for it(providing that you can get to it). I have a security laser led hidden inside my 3rd brake light which shines the light to anywhere I want.
Originally posted by 95emeraldgxe
Thanks alot for the responses guys. Now here is my second question, after i install the LED and seal it, where do i run the power too?? - where is the factory alarm in the 95's located??? I am clueless
I'm no install guru, so if anyone has any better ideas, shout 'em out!
Originally posted by KWheelzSB
If he's really hot to do this, he could always seal the backside of the LED with clear silicone caulk. That would be an easy, leak-free, zero-maintenance install.
True. I did that with my clear corners...sealed it up real good. By the way, I notice you live in the SB area. So do I. By chance do you know a good Nissan mechanic?
The only one I trust is the D.I.Y. mechanic I see in the mirror every morning. I can give you a few names of places to avoid like the plague in SB offline, if you like though.
I became a DIY out of frustration and economic necessity after several bad experiences with local shops, including the *cough* Big One. (SBN)
I just crossed 85k mi & am on schedule, maintainence-wise, but if I end up needing anything major, I'll be in the same boat as you. All I seem to have found in the local auto-repair industry is plenty of incompetent people looking for a payout. One day, I just said ENOUGH!! -& bought a Haynes manual, learned how to pull codes from & reset my ECU and I never looked back. -Solved a couple problems myself that shops were unable to diagnose, but were more than happy to overbill me to "try" and chase down.
Fortunately, the Maxima is relatively light on maintenance* when compared to a good many other cars, but when it does falter, I've learned that self-reliance is key.
On that note, if YOU find a good technician, be sure & let ME know.
Best,
-K-
*If properly cared for/driven.
Re: Koolest Alarm Led!!!!
I saw this ricer Prelude, looked nice actually.
I remember the guy had an indiglo flashing security light (square in shape, about 2"x1") stuck against his window. Was basically an outline of the car and the word security, don't remember if it just blinked blue, or if it had red too.
I'd like to get one, but I'm thinking some jerk's going to smash my window to get it.
Re: Re: Koolest Alarm Led!!!!
Varad makes one that is a laser beam, about 2 inches long and it flashes "Security" in red anywhere...except you need to find a place to mount it so it will reflect off a surface that can be seen from the outside...I bought one and sold it when I couldn't figure out where I wanted to mount it.
BTW...this is my 1000 post!
Erik
Erik
Originally posted by pocketrocket
Sorry, OT (kinda), but still related to a security LED.
Re: Re: Re: Koolest Alarm Led!!!!
Erik
Erik
Re: Re: Re: Re: Koolest Alarm Led!!!!
I think you can easily wire up any LED to the existing security light, just tap into each wire and then wire up the LED anywhere you like. I am thinking about doing 2 of these, one in front of the car in the headlight or foglight and then one in the taillight..
any problems in this idea Tony?
Sounds like a great idea too me - the only problem is that it will actually attract theives more - hahhaa - but i'm still gonna do it anyways
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
