New member-Replace started-Spedo not working???
Old Aug 13, 2012 | 10:22 AM
Max Murder's Avatar
New member-Replaced starter-Spedo not working???
Hello, new to this forum. So the story goes i bought my son a 1996 Maxima as he was about to become a legal driver. I was looking for a safe reliable car, decent gas mileage and the plan is also to teach him car maintenace it just so happened my neighbor put hers up for sale. We purchase it, original owner car with 110,000 on the spedo. We had it for about 7 months and the starter died. I called a few shops to see what the replacement job would cost, i got three quotes from $350-$450 Being that im mechanically inclined i decided this would be his first job. (he's grown up with me tinkering on old aircooled vw's so this isn't new to him entirely). We purchased the part, set aside an afternoon and i supervised the process and guided him through it. The whole job took a total of 30 minutes, far and away the easiest starter i've taken out (that wasn't an aircooled car). The big moment came when he went to see if the starter would actually start his car. Cranked right up, he couldn't get that smile off his face, he was so happy and i was so proud. So a day later he comes in and tells me the spedometer doesn't move when he's driving and the mileage doesn't rotate??? Being that he is a young driver i really need to figure out why its not working. I checked all the connections and everything looks good. I looked at a Haynes manual and it was useless. Anyone have any idea of what the problem might be.
Old Aug 13, 2012 | 12:23 PM
DBear's Avatar
Is it throwing any codes? I'd expect to see the code for vehicle speed sensor. Even if the CEL isn't on, test for codes anyway. The bulb could be burned out.
Typically, the approach is 3 steps:
1. Replace the vehicle speed sensor. Normally you don't want to just throw parts at a problem, but it was only around $25 last time I bought one. It's an easy fix. It fits into the tranny housing just a little ways past the starter. I think there are pix in a thread here somewhere.
2. If that doesn't fix it, tighten the screws on the back of the instrument cluster. This is also easy once you've done it a time or two. Again, there should be a number of threads here on getting this out.
3. If that doesn't work, replace the cluster with a used one. I got one here for around $40 IIRC correctly. You'll have to deal with the mileage difference somehow. I got one with about 12K fewer miles on it, so if I ever sell it I'll just disclose it. But I plan to drive it into the ground anyway...
Old Aug 13, 2012 | 05:56 PM
2brosgixxer's Avatar
Agreed 99.9% except that I would swap #1 and #2 around as far as order goes.
Make sure to check for codes before you replace the VSS though. Does tapping the speedo bring it back to life?
Most likely it's not the VSS (speed sensor). The speedo's on these 4th gens seem to be poorly made. Mine went out as well. I got a cluster from an org member for about $30 shipped, and another parts one for $10 shipped. My bet is on the cluster itself, not the vss.
Old Aug 13, 2012 | 06:56 PM
DennisMik's Avatar
Follow the wires to the VSS to see if they got damaged or disconnected.
If you would like to download the Nissan FSM (Factory Service Manual), go here:
http://boredmder.com/FSMs/Nissan/Maxima/
Old Aug 13, 2012 | 07:25 PM
Max Murder's Avatar
Fellas, i followed the directions to remove the starter. Reinstalled it and then the starter stopped working. Til we relaced the starter there was no issue's. I could uninstall everything again and put some electrical contact point grease on all the parts and reinstall???
Old Aug 13, 2012 | 07:51 PM
I am now confused. The starter and speedo have nothing to do with each other. You said you replaced the starter with a new one and the car started.
Here is where I am confused...You removed the new starter and reinstalled it??? Why???
Old Aug 13, 2012 | 08:05 PM
DjHackStyle's Avatar
So ur saying now the NEW starer is no longer working?
Old Aug 14, 2012 | 05:12 AM
Max Murder's Avatar
Sorry guys i mis typed. No problems with the starter. After my son installed the new starter, the spedo is completely dead.
Old Aug 14, 2012 | 07:06 AM
asand1's Avatar
Check the wires to the VSS (vehicle speed sensor). The wires may have been unplugged, or broken during the install.
Old Aug 14, 2012 | 05:43 PM
+1 For some reason I read his original post as the speedo stopped working 3 days after he starter install instead of 1 day later.
OP, theres not many reasons the speedo will stop...either VSS related or Cluster.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
