TRANSGO SHIFT KIT
Old Aug 15, 2012 | 12:45 PM
theblackone3.5's Avatar
TRANSGO SHIFT KIT
I have a transgo HD2 shift kit and some guys wanted 675 bucks to install the shift kit. I know that is way to high. How much does it usually cost to install this kit? Or should I just do it myself?
Old Aug 15, 2012 | 01:10 PM
asand1's Avatar
Does it include friction materials, or just a shift kit?
Old Aug 15, 2012 | 01:13 PM
What do you mean by friction materials?
Old Aug 15, 2012 | 02:01 PM
asand1's Avatar
Does it come with performance clutches and bands, or is it just gaskets, springs, and a plate? Some "shift kits" are more accurately called a rebuild kit. If it requires replacing clutches, $675 is probably about right. If its a simlpe shift kit you could DIY or find someone to do it for $100.00.
Old Aug 15, 2012 | 02:19 PM
Well can you tell me? the Transgo shift kit part # RE4F04A-HD2.
Old Aug 15, 2012 | 03:57 PM
a
Old Aug 15, 2012 | 04:00 PM
Amerikaner83's Avatar
seriously? "a" is all you got?
asand isn't your mommy...he (or anyone else) isn't going to TELL YOU anything...it's up to you to do some ******* research and see if the shift kit you referenced above (WITH PART NUMBER for chrissakes!!!) is what you think it is.
Jesus H Christ!
Old Aug 15, 2012 | 04:04 PM
Just seeing if the kit has friction materials? Calm down man. Just seeing how much it would cost if i didnt want do it myself.
Old Aug 15, 2012 | 04:17 PM
maxed_out_99's Avatar
i have that kit. a professional trans shop that doesnt have its eye on you wallet should knock it out in about 2 hours it will run you about 150-300 bones depending on the shop 675 is a ripoff
oh and by the way the "shift kit" part number before the HD2 is the trans ID HD2 is the part number
you could do it yourself but if you never have taken an auto apart you could easily screw yourself
Old Aug 15, 2012 | 04:26 PM
Thanks, maxed_out_99. How do you like the HD2 shift kit? Positive or any negative reviews about the transgo kit
Old Aug 15, 2012 | 06:14 PM
any more ideas about the shift kit?
Old Aug 15, 2012 | 10:52 PM
I love it. It shifts super hard it pretty much damn near slams gear.
You know if your going up a hill an your in a high gear the RPMs start to fall so you put your foot into the throttle and wait them wait and wait some more then you hat your neck snapped because you were bogging at 30 in overdrive. That's gone.
The RPMs go all the way to redline in every gear no lag in between shifts
Old Aug 16, 2012 | 08:52 AM
Did you install it yourself? Or did u take it to a transmission shop? if so how much did it cost for you?
Old Aug 16, 2012 | 11:04 AM
How much for install for you?
Old Aug 16, 2012 | 11:19 AM
carsnwomen91's Avatar
lol this isn't fb chat or msn messenger... you gotta be patient for a reply
Old Aug 16, 2012 | 11:22 AM
i know, i'm trying
Old Aug 16, 2012 | 01:27 PM
Thank you.
Yeah I have a full time job, wife, and 11 month old son you know a life. Sorry I'm not on the forum 24/7
but to answere you question a real good friend of mine had a job at a trans shop (now he moved on) so he installed it for me for 40 bucks.
I drove an hour away removed my valve body in his driveway then installed it after the kit was installed. It took my buddy 45 minutes to install
Old Aug 16, 2012 | 01:29 PM
Originally Posted by maxed_out_99
Thank you.
Shut to answere you question a real good friend of mine had a job at a trans shop (now he moved on) so he installed it for me for 40 bucks.
Sorry for the horrible spelling and wrong words I have a retarded iPhone "looks like you spelled shifts correctly I'm going to change it for you to stops" SMH
Old Aug 16, 2012 | 07:43 PM
Does anyone know any good or great transmission shops in the dfw area? Location around garland, sachse, wylie, or even dallas.
Old Aug 17, 2012 | 06:30 AM
location, location, location
Old Aug 17, 2012 | 10:09 AM
jsleezayy's Avatar
Jesus H Christ!
Seriously? Just because he asked a question before he spends 500 bucks he doesn't need to spend? Way to be a tool.
Old Aug 17, 2012 | 11:02 AM
Amen brother!
Old Aug 17, 2012 | 11:28 AM
Rods03Max619's Avatar
This, thats what they wanted to charge me 150 to install the kit, 675 way to high my guy would swap the engine for 500......
Old Aug 17, 2012 | 11:35 AM
I didn't let them install. They were trying to rip me off for sure! I'm trying to find a good transmission shop in dallas or I will install it myself
Old Aug 17, 2012 | 11:54 AM
2000_MAXIMA_KING's Avatar
I installed mine myself and it was my first time...
here's my review and tips on doing the install
http://forums.maxima.org/all-motor/6...kit-today.html
Old Aug 17, 2012 | 02:11 PM
I see you have the 2000 maxima. Do the same steps apply for a 1996 maxima? Are they the same trans? Just let me know
Old Aug 17, 2012 | 04:39 PM
They are not exactly the same but very similar. Just follow the instructions that come with it and they should be the same steps maybe just a little different.
Old Aug 17, 2012 | 05:16 PM
they are actually very different. i have a 5th gen trans the 4th gen valve body is completely different. the solenoids, fluid routing, gaskets, theyre all different.
there is gaskets that are in between the valve body. the valve body is actually in three pieces. on the 5th gen the gaskets are bonded so i didnt replace them. on the 4th gen theyre not bonded so it would be recommended to replace them the kit should have them in it.
the steps to install it should be about the same if you do it yourself just make sure you dont loos track of what bolts go where cuz theyre all different sizes. and make sure you torque everything to spec or you will have all kinds of problems. the transgo kit has awesomely detailed instructions so it should be easy to tackle if your mechanically inclined.
i recommend to open the kit and read through the instructions. if it seems over your head, pay someone. but dont pay them 675 no more than 200. 300 if they include a flush, vehicle inspection, tire rotation and oil change.
Old Aug 17, 2012 | 06:52 PM
thanks for all the advice. you guys have been great!!
Old Aug 18, 2012 | 04:34 PM
bump
Old Aug 22, 2012 | 12:49 PM
DBear's Avatar
Maxed_out--Do you mean torque the valve body bolts? What kinds of problems can you get if they aren't torqued properly?
Old Aug 22, 2012 | 03:16 PM
What does 3k stall mean? Can you do that only after you install the shift kit?
Old Aug 22, 2012 | 05:12 PM
yes the valvebody to case bolts.
the problems you will experence are; a flare in between gears, falling out of gear, poor shift quality, slips, it will be all sorts of screwed up
Old Aug 22, 2012 | 05:16 PM
that has to do with your torque converter not the trans or valvebody. to check where your stall is, with the engine running and the car in drive stomp on the brake pedal and hold it with all your might. then accelerate the engine until the RPMs stop climbing. whatever RPM they stop at is your stall. a new torque converter will give you a higher stall. Theyre around 500-750 though. theyre not cheap but its worth it if you have some good mods
mine is at 2000-2200
with a 5th gen TC
Old Aug 22, 2012 | 08:45 PM
I've installed 2 transgo hd2 kits on 5thgen maximas and I didn't torque a single bolt. I was actually advised not to by a local trans specialist the first time I was doing it, he said the threads are like butter and it's very easy to strip them and after doing them I agree. You will see when you pull the VB the bolts are just on there snug, so just snug them back up the same way. Feel the VB afterwards, if it is not on there tight then something is wrong, if it's on there tight then you are good to go. This is just my opinion.
Old Aug 22, 2012 | 09:45 PM
Don't ever go back to that trans guy he's an idiot. The torque spec is there for a reason so you don't strip them DUH. Do it right or don't do it at all
Old Aug 23, 2012 | 09:57 PM
atxking27's Avatar
just follow the trans-go instructions and do it yourself. They are idiot proof. If you can read, then you can install the kit yourself. Can't rush it, and buy a torque wrench. All the torque specs are on the instructions.
Old Aug 23, 2012 | 10:18 PM
How much would i look for if i dont want to install it myself? Some trans shop I talk to want way to much to install the shift kit.
Old Aug 23, 2012 | 10:52 PM
I told you homie, 150-200 that's fair unless theyre rebuilding your trans
Old Aug 24, 2012 | 12:31 AM
Ya people want 400-600 bucks!!!! Still calling around though. Hopefully get a good price soon. People trying to rip you off, when all been there.
