MAF sensor fixing
Old Aug 16, 2012 | 02:27 PM
ADHDadditiv's Avatar
MAF sensor fixing
I couldnt find any post on the forums about this, so im asking now. Where would I buy a new MAF sensor? Where is it located in the engine bay? How would I go about replacing it?
Thanks in advanced!
Old Aug 16, 2012 | 05:32 PM
kel456's Avatar
chances are slim to fix this damn sensor. from reading threads, if you were using K&N like products then you can give it a shot with isopropanol to remove possible oil. fine spray on the wire like areas and follow with water then let it dry. location is between the air box and the throttle body. ebay MAF is crap. so obvious next step is junk yard or stealership. i am always curious why MAF is so damn expensive.
Old Aug 16, 2012 | 07:20 PM
asand1's Avatar
Old Aug 16, 2012 | 08:20 PM
isandres8884's Avatar
Old Aug 17, 2012 | 11:07 PM
OlgaGarrett's Avatar
pretty little liars season 2 dvd
one tree hill season 9 dvd
Old Aug 29, 2012 | 02:07 PM
got a quote from Lordco... $768....
Found one http://shop.massairflow.com/Nissan_M...031u00maf4.htm for 79.99
Old Aug 29, 2012 | 02:39 PM
Buy a used OEM one. Put up a WTB in the classifieds.
Old Aug 30, 2012 | 07:30 AM
bobflood's Avatar
Look for a "reman" OEM MAF, not an "aftermarket" unit. I got one from Autopartsexpress.com for about $160 after core return. It's been on about 18 months with no problems. Had to chase them a bit to get the core money back. Also replace the "isolator" - the thick rubber piece between the MAF and throttle body - new from Nissan for abt $12. Piece of cake DIY job - 4 bolts, one electrical connector, right on top of engine between air box and throttle body.
Old Aug 30, 2012 | 10:54 AM
cashoit's Avatar
+1
Autozone has reman MAFs.
Old Aug 30, 2012 | 10:59 AM
ajm8127's Avatar
I used an A1 Cardone remain unit when I had a problem. I also still have my OEM one. I removed the cover and found one of the three terminals had a bad solder joint. I re-soldered it but haven't tested it yet. I'm almost positive that was the problem because the symptoms were indicative of a bad connection. I'll sell you the fixed OEM one for 50 bucks.
-ReLLiK-
Apr 29, 2016 06:25 PM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
