3.5 Swap FPR Question
Old Aug 24, 2012 | 09:24 AM
Maximeltman's Avatar
Fuel Pressure Regulator, for mimicking a returnless fuel system. I just got one of ebay for like $19, and of course has no instructions, but I think I might have figured it out, but to be sure, can you guys help verify the fuel locations on the pump at point A B and C:
Here is what I think
A-from filter
B-To tank
C-fuel damper
Also, what are these for:
Any help I'd really apreciATE very much, thanks!
Old Aug 24, 2012 | 01:55 PM
RA030726's Avatar
I'm nutty for Nissans
A- Inlet
B- Outlet
C- Vacuum
The fittings bolt to the fuel rail in place of the original regulator. You can then run hoses from barb to barb and place the new regulator where ever you like.
Old Aug 24, 2012 | 02:47 PM
Originally Posted by JSutter
A- Inlet
B- Outlet
C- Vacuum
Thanks man! I also found that diagram when I searched 'ebay fpr installation' lol
Also, anybody got a pic of theirs installed by any chance?
is this where the connections are in relation to above:
Old Aug 24, 2012 | 10:02 PM
deloa84's Avatar
Here is the pic of mine installed. I did not hook up the vacuum or C but if you look at the FSM vacuum diagram, it will tell you exactly where it goes....
https://skydrive.live.com/redir?resid=F5819D52DBC2A0C2!998&authkey=!AJF81CSz Fad54z4
Old Aug 25, 2012 | 03:34 AM
Thanks! Your fuel rail is different than mine what year Maxima engine is that?
EDIT: looks like it's a 2004 fuel rail. I think I have the 2003.
Old Aug 25, 2012 | 08:40 AM
deloa84's Avatar
Its an 05 maxima engine.
Old Sep 2, 2012 | 04:04 PM
So does the 2003 Maxima utilize a returnless fuel setup? I ask because it looks like the damper shoots the unused fuel back to the tank. I don't want to asume anything and then have lots of fuel dripping all over the place!
Old Sep 2, 2012 | 05:57 PM
deloa84's Avatar
The 03 utilizes a returnless system. The only difference from yours to lets say mine (05) is the design of the fuel rail. The fuel rail on the 03 has two inlets where as mine has one inlet... Here is a somewhat helpful link
http://forums.maxima.org/all-motor/5...e-routing.html
Old Sep 3, 2012 | 07:15 PM
Good, so I will either plug one end or run fuel to both inlets. Since I'm only NA, probably no need to do the latter.
Thanks again deloa84, udaman!!
Old Sep 16, 2012 | 11:26 AM
I noticed when I started my engine, the fuel went shooting out the other damper at point A, so does this mean this fuel rail HAS a return? I thought the 3.5 uses returnless fuel rail, and the fuel escaping has me thinking its return?
Can someone clarify?
I<3 A32's
Sep 10, 2015 11:07 AM
MaxLife17
Sep 8, 2015 02:36 PM
JoshG
Sep 5, 2015 10:10 PM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
