Engine Ping/Thump.
Old Aug 24, 2012 | 11:26 AM
arrazola_a's Avatar
Engine Ping/Thump.
I did a tune up on my 96 max about a month ago and noticed some bad pinging while in D at a stop. I changed the spark plugs fuel filter air filter oil and oil filter blah blah.. i noticed when i was on the last plug that the coil has a small amount of oil on it. i cleaned it off replaced the plug and my car was running great. the next day is when i first noticed the "thump". everyday since then its gotten worse. any ideas? i already searched for ever and still cant find anything.
No check engine light either.... also i cleaned out my tb. help please i want my max back
oh also i realized it only does it while in gear . when its in park it doesnt ?
Old Aug 24, 2012 | 11:48 AM
Amerikaner83's Avatar
Check for codes, even though you don't have a CEL.
Does it "thump" now, at the same times /places it used to ping? Describe the thump...at speed/rpm? do you hear it or feel it?
which plugs specifically did you use when you changed 'em?
Old Aug 24, 2012 | 06:31 PM
T_Behr904's Avatar
Are you using premium fuel?
Old Aug 24, 2012 | 11:00 PM
SVI30's Avatar
...i noticed when i was on the last plug that the coil has a small amount of oil on it. i cleaned it off replaced the plug and my car was running great....
Oil in sparkplug tube is due to leaking tube top seal. I have two tubes with oil in them on the back bank. Finally pulled the valve cover and replaced them. Oil in sparkplug tube doesn't hurt anything.
Old Aug 28, 2012 | 11:38 AM
arrazola_a's Avatar
It didn't do it before i changed the spark plugs. its more of a thump/tug and only does it under 1000rpm . i used autolite double platinum. im wondering if it has to do with the spark plugs because thats when it started. i will post a video to give better detail
Old Aug 28, 2012 | 11:40 AM
arrazola_a's Avatar
before i changed my knock sensor i was using 87 but after that i filled up on 91 which is the highest i can get in phoenix.
Old Aug 28, 2012 | 11:43 AM
arrazola_a's Avatar
i manually checked for codes using the ecu and nothing came up but 5-5 which i believe is nothing
Old Aug 28, 2012 | 11:44 AM
YES.
Go to NGK platinum this time. Our cars like NGK plugs.
If it didn't do it BEFORE the plug change, then undo that action and try again.
Old Aug 28, 2012 | 11:56 AM
arrazola_a's Avatar
http://youtu.be/WuMxlwdSFNE
here is the link
very hard to describe! when i have some cash to burn i will get those ngk plugs.
any special make i should consider? i seen those ones you dont need to gap but not sure if those are even worth it or not. thanks!
Old Aug 28, 2012 | 12:28 PM
Fauken's Avatar
Rule of thumb for spark plugs with our cars is simple,
NGK or bust!!
Now which ones you choose to run is different (coppers/platinum/irridium)
Old Aug 28, 2012 | 12:32 PM
NGK or bust!!
yes...and to expand on that:
Platinum is OEM, will last a long time (60-100K) before needing replacement
Copper ignites slightly hotter, but lasts only 20-30K
Iridium is overkill for standard VQ motors.
Old Aug 28, 2012 | 01:04 PM
asand1's Avatar
This is not accurate. Hot oil breaks down the rubber coil boot and will cause arcing and a miss on that cylinder.
Old Aug 28, 2012 | 01:05 PM
arrazola_a's Avatar
Thanks. i forgot to mention that i changed the ks at the same time. i used an ebay one i got for about 10 bucks shipped. that should have nothing to do right?
Thanks for the quick replies the org is awesome!
Old Aug 28, 2012 | 01:06 PM
yeah...KS should not be relevant to your current issue.
Old Aug 28, 2012 | 01:08 PM
arrazola_a's Avatar
i just checked the last spark plug located in the rear passenger side and it was drenched in oil. i cleaned out all the oil in the bank and replaced it with a new spark plug. no change. could it be the coil? thanks!
Old Aug 28, 2012 | 03:09 PM
asand1's Avatar
Wrap the rubber boot with electrical tape for testing purposes and see if it doesnt run better. New boots are available, front and rear are different.
Old Aug 28, 2012 | 03:26 PM
luke95gxe's Avatar
this ^ is what i was just getting ready to say
Old Aug 28, 2012 | 04:34 PM
arrazola_a's Avatar
Can you expand on that. Im not 100% sure what you mean. Yes i am a noob lol
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
