eng codes and no start
ok so working on this car for a friend at work claims she put so much money in it and had stupid people working on it
soooo
95 maxima no start she claims to have gone thought a few starters
so i pulled that out.
took out the crankpos sensors cleaned and put back in they look like they have been replaced
i did see a code for a sensor and others but deleted codes before working on car but it wont start to make new codes
i get no spark and cant say its the crank pos or ref sensor just yet testing starter in a few
soooo
ok so starter was bad lol
ok so work done so far from what i was told
ground kit :i moved to trany and block have to clean frame ground
but here is the kicker i found out to day shes blowing starters this one i changed was number 5 lol
she claims hard starts and keeps cranking and cranking blow starters
i am thinking fuel problem i got a filter and will see if that help and may have to rent a fuel presure test kit
or am i missing something that would make a car eat starters like that in a year or so
some lasting a few weeks to a few days
fyi new starter not going in yet till i find problem
Turn engine over by hand and inspect the flywheel gear. Hard starts will kill the starter by overworking it.
Are you getting consistent spark? pull a coil and plug and reconnect laying on the valve cover.
yeah going to have to turn eng maybe bent flywheel ?? can i pop start a auto trany i never looked or tried not sure on spark was hoping it was just fuel filter and bad starter so i found out oldguy changed all there sensors for cam ref and pos so time to test them
got alittle noise after turning by hand may have been a bad tooth idk still no fire and dont really feel like playing with it to day lol questions for tomorrow
dont think i am getting spark
i hear fuel pump buzz but maybe dirty sock or not at 100%
what is resistance from crank pos and ref sensors i was told 5 ohm
and on top of end he cut wires for cam position sensor :from ecu white wire and a black
replacement sensor is yellow and red what one is ground on sensor
sctludwig
Sep 1, 2022 01:32 PM
trungg86
Sep 4, 2015 04:58 AM
