95 max interior dome light dead
Old 09-15-2012, 09:17 PM
Rob_0126's Avatar
I had a dome light blow. So i replaced the bulb, and still no go.
All other interior lights and exteriors work; fuse is good.
Any clue of the culprit other than a broken wire in the roof?
Rob_0126 is offline
Old 09-15-2012, 09:43 PM
Amerikaner83's Avatar
you replaced it with the proper bulb, yes? Or did you put an LED in it? Stupid question but you have the dome switch in the proper position, yes?
Amerikaner83 is offline
Old 09-15-2012, 11:19 PM
DennisMik's Avatar
Have you checked fuses? If you blew the fuse the step lamps (the lights in the door) will not work. Get a volt meter or a test light and see if you have power on one side of the light bulb all the time, regardless of the dome light switch position. The dome light switch is 3 position - off, on with door, and always on. The center position is the "on with door" position.
DennisMik is offline
Old 09-16-2012, 04:40 PM
Rob_0126's Avatar
Yep fuses fine and tried every switch setting.
Also used exact same bulb for replacement.
All other interior lights work and exterior.
Rob_0126 is offline
carguy96
20
02-06-2021 06:21 AM
vingodine
45
05-21-2016 12:46 PM
Slamrod
04-10-2016 05:24 PM
King_Ten_Ahead
09-30-2015 04:27 PM
rbaker100
08-28-2015 08:11 PM
Quick Reply: 95 max interior dome light dead
