IACV is different for 1999 model year compared to 1995-98?
It will still work. Any would work. I think Nissan changed company from where
they got their parts or something but that is not going t o affect functionality.
Here is a good comparison
http://cdn1.autopartsnetwork.com/ima...1724454OEA.JPG
vs
http://i.ebayimg.com/t/95-96-97-98-99-NISSAN-MAXIMA-I30-IDLE-AIR-CONTROL-VALVE-SENSOR-/19/!ByQiSiQCWk~$%28KGrHqJ,!i!Ew5FV5-9dBMQ689uHq!~~_35.JPG
They look different but function the same...
vs
actually if youd like to be technical...it depends on what your manufacture date is for your 99... some came with the same iacv as the 2000...mounted under throttlebody..some have the triangle looking iacv...i also have a 99 se-l and mine was originally mounted under the tb.....since the previous owner swapped motor and installed mevi i now have the triangle looking one...for now....dek swap in the works...
The rear answer is simple. 99s have a plug where the purple fast idle solenoid is supposed to be installed. It can be swapped over.
http://forums.maxima.org/4th-generat...-gen-iacv.html
trungg86
Sep 4, 2015 04:58 AM
