starting problem
Old Sep 28, 2012 | 11:53 AM
lennyk69's Avatar
starting problem
i replaced the fuses, battery and alternator are good. car turns on but when i try to start it it just clicks once and nothing happens. it this the starter?
Old Sep 28, 2012 | 12:14 PM
Sounds like your starter. Try tapping it with a hammer, then start it. If that works then it's time to replace it.
Old Sep 28, 2012 | 01:22 PM
Justaguy's Avatar
Correct.
The starter is located way down on the driver side. Get a long stick, place it on the starter and use a hammer to hit the stick. This may help to start the car once or twice...or none at all
I had 2 starters go back on both my maximas...all you hear is a click.
Old Sep 28, 2012 | 05:39 PM
goliath's Avatar
Is the click coming from the left side of the dash by the fuse panel? If so, try replacing the ignition switch. This was my problem. Apparently these switches are a common fault in 4th gen maximas. I confirmed the switch was the problem by checking continuity in the harness. when the switch is turned to the start position, connect your digi meter to the black-white wire and the other lead to ground. You can just undo the harness under the dash and test the pin instead of taking the switch out to perform the test. If you have continutity, it is not the switch. if the meter doesnt move, change the switch.
Old Oct 1, 2012 | 01:34 PM
DBear's Avatar
If you're taking the ignition switch out, try starting by putting a screwdriver in the slot in the switch. If it starts every time, you probably have the slop issue.
There's a slot in the ignition switch that fits into a little T shaped flanged in the steering column. As these cars get older, they develop a little slop between the flange and the ignition switch, and sometimes turning the key doesn't quite make the ignition switch go far enough over. I solved it by putting a tiny piece of electrical tape in the slot on the switch, like this:
http://s397.photobucket.com/albums/p...Ignition-1.jpg. But after a while I found that the tape would slip out of place, so I graduated to SlopFix 2.0. I cut a little piece out of a coke can and crazy glued it to the inside of the long edge of the slot. Someone else duck taped the **** out of it. You just need something to fill in that gap.
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
