Reason for wheel hop?>>
Old Jan 8, 2002 | 02:17 PM
190hpKiLLA's Avatar
Granny Driven
I want to know why my 4th get has wheel hop. I only did it like 5 times. Thanks.
Old Jan 8, 2002 | 02:55 PM
SuDZ's Avatar
http://forums.maxima.org/showthread....heel+hop+cause
SuDZ
Old Jan 8, 2002 | 10:41 PM
190hpKiLLA's Avatar
Granny Driven
Thanks but no thanks. That post doesnt explain ****. When we went to the track Steve with his brand new 2k2 had wheel hop also. Anyone else has an answer. Thank you.
Old Jan 8, 2002 | 10:48 PM
96max's Avatar
What springs are on your car? Looks very low, or is that just photoshop?
Old Jan 8, 2002 | 10:52 PM
95emeraldgxe's Avatar
can u be more specific when u say wheelhop???
Old Jan 9, 2002 | 12:31 AM
ericdwong's Avatar
Its because we have FWD cars with soft rubber bushings and a relatively torquey motor. FWD is already at a disadvantage. The weight transfer, and because the front wheels steer, brake and accelerate the car as well as hold most of the of weight is another reason. This is because of all the play needed to accomodate all these functions. Wheel hop is when the tires are on the verge of hooking up and breaking loose, so its that happy median.
One solution would be radial arms, http://hybrid.honda-perf.org/tech/z10.html but nobody makes them for us (yet). Other solutions include polyurethane motor mounts and control arm bushings, as well as a lowered/stiff/damped suspension.
Old Jan 9, 2002 | 01:25 AM
KWheelzSB's Avatar
The answer is there if you're willing to accept it. The engine mounts made by Place Racing will eliminate 98% of wheel-hop. If that's your problem, that's your solution.
Old Jan 9, 2002 | 07:32 AM
max7's Avatar
The only problem is your car starts to vibrate!
Old Jan 9, 2002 | 11:33 AM
SuDZ's Avatar
What about them makse your car vibrate?
SuDZ
Old Jan 9, 2002 | 01:17 PM
KWheelzSB's Avatar
SuDZ
The engine mounts serve two purposes:
1) They hold the engine/tranny firmly in place
2) They insulate the rest of the car from engine vibrations.
Once you realize that these two goals are in direct opposition to one another, you then understand that when you use a denser (firmer) insulating material in the mount (Say polyurethane, instead of the OEM rubber), this holds the engine/tranny in place better, but at the expense of transmitting a bit more engine/tranny vibration to the rest of the car. . .
The OE engine mounts are a compromise, designed to address both of these needs as equally as possible. If the wheel hop bothers you that much, get the P.R. mounts, but be prepared for more vibration in the cabin.
Old Jan 9, 2002 | 01:32 PM
max7's Avatar
Thank you!
Old Jan 9, 2002 | 01:43 PM
Keven97SE
When I installed Koni shocks on the front, almost all of my wheel hop went away. It's not a problem anymore. Soft struts allow the wheel to oscillate up+down too easily, which is what wheel hop is.
Get better front struts and I think the problem will go away. Tokico blues suck.
Old Jan 9, 2002 | 02:09 PM
SuDZ's Avatar
That makes sence. How firm do you keep your Koni's set for?
SuDZ
Old Jan 9, 2002 | 03:56 PM
KWheelzSB's Avatar
SuDZ
I agree - good idea: the strut/shock upgrade. Hadn't thought of that. It would be a smart way to address this problem, because it's an upgrade you'd want to do anyway, for all the right reasons.
If you're shopping now though, go w/ the KYB AGX. Koni's are great, but AGX is the new king of the jungle for less $, (plus, no mods required for install).
Old Jan 9, 2002 | 04:04 PM
Keven97SE
I have my front Konis set for 3 half turns out of 5 maximum. That seems to be the best comfort vs performance compromise. At 4, handling was sharper but the ride was definitely choppier/harsher. Still not terrible, but too much over time for me. I have H&R springs, BTW. The Konis (all around) plus H&Rs handle really well but are still reasonably comfortable with my Koni settings.
SuDZ
Old Jan 9, 2002 | 04:35 PM
i never had wheel hop before.....
Old Jan 9, 2002 | 05:16 PM
KWheelzSB's Avatar
If your car does have "three pedals," & you've never had wheel-hop, it's 'cause you're not launching hard enough!
(It really only happens* when your doing a drag-style launch with a healthy amount of feathering of the clutch). It's accompanied by a violent amount of vibration - the dashboard pretty much sounds like it's going to shake apart into a million pieces - there's no mistaking it).
*On a "lightly" modded Max. S/C & Nitrous vehicles can have wheel-hop under hard accelleration if not equipped w/ the right struts or P.R. engine mounts (because of all the extra torque being transmitted to the engine mounts).
Old Jan 9, 2002 | 08:39 PM
190hpKiLLA's Avatar
Granny Driven
Thank you guys. I will ge getting new shocks/springs soon.
Old Mar 16, 2002 | 11:57 PM
190hpKiLLA's Avatar
Granny Driven
Well..... I got new shocks/springs and still have massive wheel hop.
There were 2 bimmers around me and I tied to race them but got wheel hop all though 1st gear. I should of let go but I was sooo stupid to continue flooring it.
How bad is wheel hop for the car because I hope it wont harm it by accidently happening few times. I felt so bad for it.
Are place racing engine mounts that harsh to ride on?
Old Mar 17, 2002 | 07:42 AM
Nismo87SE's Avatar
Excessive wheelhop will destroy engine/tranny mounts and tranny cases if its bad enough. All you can do is get/make stiffer engine mounts, the increas in vibration isn't much.
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
